Old 02-25-2015, 02:55 PM   #1
Scissor jacks without mounting
I want to put scissor jacks fore and aft of my axels on the frame to remove bounce in the center of the trailer, but I dont want to mount them, i currently use stack jacks but these can be a pain to place. What do you guys think?
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 02-25-2015, 02:58 PM   #2
Why not mount them and eliminate having to "place" them and store them?
Old 02-25-2015, 03:08 PM   #3
Brother Les's Avatar
What you want are called 'save a jack'. I bought mine at Camping World. If you go on CampingWorld.com and check their price.... If you live close to a Camping World, they will sell it to you for the price on the Dot.Com as a price comparing. The slide in bracket is permantly mounted to the unit and the scissor jack has a bracket to slide it in. I did not want the scissor jacks hanging down going down the road. Works really easy.
Saveajack - 2pk - Curry Enterprises SAJ-U - Stabilizing Jacks - Camping World
Brother Les
Old 02-25-2015, 03:19 PM   #4
If they are mounted for and aft of the axles, it would be pretty difficult to drag them off without major damage in other places. Have never dragged a mounted jack in over 50 yrs of pulling trailers.
Old 02-25-2015, 03:27 PM   #5
From the Pictures of his unit, it sits closer to the ground. He will drag in certain conditions. had a unit fairly like that and over the years drug both 'drag bars' off of it and once in a while skidded (drag) on the back bumper.
Brother Les
Old 02-25-2015, 03:37 PM   #6
Doesn't sit any lower than my Flagstaff 8528RKWS and he wants the jacks right in front of and right behind the axles.
Old 02-25-2015, 03:42 PM   #7
Your coming down to my level again..... stop that,... my medication is wearing off....
He asked for a suggestion and I gave him one and you gave him one.
His camper... So...he will do what the DW says is best.
Have a great day, OC.
Brother Les
Old 02-25-2015, 03:59 PM   #8
Ret E-9 Anchor-clanker
donanddona's Avatar
I still hyd. bottle jacks at the front axel. Works for me.
donanddona is offline   Reply With Quote
Old 02-25-2015, 04:47 PM   #9
Thanks for all the advice guys. my dealer said he could mount some there for me but I thought scissor jacks would just be quicker to pop down and run the drill to raise them.
They wouldnt scrape anything being at the axels if I mounted them there.
Those stack jacks just take forever to set up and I usually have to lay on my back to get them in position, and then start screwing (not the fun kind).
I use 4, 2 in front and 2 behind
Old 02-25-2015, 04:52 PM   #10
Here is how I mounted mine so they could be removed easily. (Which I did when I traded them to Herk). BTW, one bolt instead of 2 is enough.
Name:	Driver Side Axle Jack Retracted.JPG
ID:	70255   Click image for larger version
Name:	Axle scissor jacks 1.JPG
Old 02-25-2015, 05:09 PM   #11
To do it 'right' (imo), if you are going to the corners now, then you 'need' 6 scissor jacks . one set in front of the axles and a set about a foot or so back from each corner (not on the bumper, but on the frame). Set up like this, you can release any pressure off of the tongue jack. And if you have no jack if you had a flat, to put under the axle plate/bolt (not on the axle as it will bend) You can lift the axles/tires off the ground.
It is your unit. What ever you do, do it correctly in mounting to the frame so there is no question about the safety of it.
Safety first and always.
Brother Les
Old 02-26-2015, 11:07 PM   #12
removable Jack
Check this sight on Amazon, It is a removeable bracket for jacks.
http://www.amazon.com/Mounting-Brack...ustomerReviews
NorSnrub is offline   Reply With Quote
Old 02-27-2015, 12:31 PM   #13
Camping World sells them for 90.00 cheaper
Brother Les
Old 02-27-2015, 03:26 PM   #14
Helmsey's Avatar
I have 2 older jacks that I keep in the front of the 5er for times when we will be sitting still more than a couple nights. I just use the drill to run them up and down as needed.
I will say this: on our current 5er with hydraulic front landing gear and electric rear stab jacks I use them a lot less. On our last campers I always had the drill out anyway so it was no big deal to put these out. Now, I only need the drill if I'm putting these out and I've found its less hassle when setting up to just not do it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
jacks, mount
