Old 05-16-2015, 12:32 PM   #1
Rico1971's Avatar
Screen replacement in bunk window
Found out today that my youngest put his hand thru the screen in his bunk during our last camping trip last year. Screen/spline came out of the screen frame...not a tear...so should be an easy fix IF I can figure out how to get the screen frame out of the window. The one edge of the screen is covered by the glass Click image for larger version
Name:	ImageUploadedByForest River Forums1431797543.985468.jpg
ID:	77100window, so the only way to repair is to actually remove the screen frame.
Anyone know how to get the screen frame out???
Thnx!!
Rico1971 is offline   Reply With Quote
Old 05-16-2015, 12:45 PM   #2
Window screens are usually spring loaded side to side. (Might be up or down as well). Just push to one side and you should feel the spring give and pull out the opposing side. Might be a little tight, mine was very tight, but did spring out.
2002 GMC Sierra 2500HD Duramax
2008 Rockwood Sig Ultra Lite 8315SS
Livin the Life is offline   Reply With Quote
Old 05-16-2015, 12:47 PM   #3
Ford Idaho's Avatar
There are springs that hold the frame in place you will need to press down or up or to one side or the other depending on where the springs are in that frame.
Not sure if the frame will need to come in or out for removal.
Old 05-17-2015, 02:10 PM   #4
Rico1971's Avatar
Success!! Thnx for the info. Just had to use a bit more force and show it who was boss!! All fixed and looks like new!!😀👍🏼
replacement
