Old 05-13-2018, 07:24 PM   #1
Sealant Catalina
What kind of sealant is used on the marker lights on a 2016 Catalina? It feels like silicone but I want to make sure.
electrician549 is offline   Reply With Quote
Old 05-13-2018, 07:39 PM   #2
rsdata's Avatar
silicon is OK on the metal, fiberglass, etc, body but never on the roof or on anything touching the roof or roof seams
2014 Shamrock 183
Old 05-14-2018, 08:33 AM   #3
JohnTr4a65's Avatar
IMHO I would not use Silicon, it lifts and separates in a short period of time and must be completely removed and thoroughly cleaned prior to resealing. The only place I use Silicon is to fill the 4 screw holes on the refrigerator cap and vent caps so I can easily pull out to remove caps if needed. Otherwise I use Geocel Pro Flex RV on the exterior walls and Dicor self leveling lap sealant on the roof.
JohnTr4a65 is offline   Reply With Quote
Old 05-22-2018, 08:50 PM   #4
should be dicor or butyl tape.
spdracr39 is offline   Reply With Quote
cat, catalina, seal
