Old 04-29-2019, 06:23 PM   #1
swampdonkey772's Avatar
Sewer hose question
I have 2 dump ports. One in the front that has the black and front gray tank, and one in the rear that has the kitchen and outdoor sink. I had to dump the rear one mid trip last outing and that sucked. Having to pull the hose off the front then attaching the rear to dump. So in the interest of me being lazy and wanting everything nice and neat what's y'alls thoughts on running ABS from the back tank up to the front dump port. I'm trying to not have to do the whole Y connector into sewer hose from both tanks but if that's my only option i will
swampdonkey772 is offline   Reply With Quote
Old 04-30-2019, 03:46 AM   #2
Witch Doctor's Avatar
There is no problem doing that if you have the room and can have a little fall so the water doesn't just sit in the new section. A lot of folks have replumbed there waist systems. And yes the Wye will work but it's a PITA.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-30-2019, 02:29 PM   #3
Thank you. Do you know how much fall i should have
Old 04-30-2019, 03:02 PM   #4
My brother had one with the two ports far apart.
His solution was to put a cap on the rear port (galley/outdoor sink) that had a garden hose connection and also an elbow for the in-ground sewer connection with the same.
He simply attached the large sewer hose to the front dump port and an old garden hose to the rear (galley) port and both went to the in-ground sewer connection.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 04-30-2019, 03:03 PM   #5
CincyGus's Avatar
Be mindful of your ground clearance of the new pipe.
I would think an inch of drop per 5'-10' would have it running dry.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 04-30-2019, 03:21 PM   #6
It won't be any lower then the current drain pipe. Im going to have to pull the underbelly and investigate. I have to deal with going over the axels so it all might be a mute point anyway.
Old 04-30-2019, 03:22 PM   #7
Didn't know they made an in ground connection like that. Do you know if they make one for the rhino hose
Old 04-30-2019, 03:24 PM   #8
I don't know?
I could spend some time Googling it but it will need to be later as I'm into some other things right now.
Old 04-30-2019, 03:25 PM   #9
I don't know?
No problem I can Google.
Old 04-30-2019, 03:49 PM   #10
B and B's Avatar
Code is 1 inch per foot. So 10 inches for 10 ft.
Old 04-30-2019, 03:54 PM   #11
That's code for a sewer line at our homes
