03-28-2019, 09:41 PM
skylight in shower
Hi
I just got my brand new 2019 Apex Nano 203rbk. Absolutely love it after searching long and hard.
I have noticed that there is condensation in the skylight above the shower. Picture attached.
There is a clear plexiglas panel above the shower and then the bubble skylight above that.
Will this moisture dissipate over time or is it something I should get addressed with the dealer ? Never noticed it when I picked up the trailer a couple of days ago, didn't even look at the skylight when I did my PDI. I Know, my bad
Any help would be greatly appreciated
03-28-2019, 09:53 PM
Could just be condensation from whatever temps and humidity you currently have, or it could be an indication of a leak. You could drop the inside piece and dry it out and see if it returns.
03-28-2019, 10:35 PM
I had the same issue. Take a shower and the outer clear bubble was full of condensation.
I dropped the interior panel and noticed the dbl sided tape attaching the translucent lens to the facia had failed ( letting air pass through). I sealed it with caulk.
I then got some wide foam tape and sealed the facia to ceiling. ( not visible though)
This should keep the humidity out of the attic.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
03-29-2019, 08:36 PM
thanks for the suggestions. I contacted the dealer and it will be warrantied.
04-09-2019, 11:07 AM
Chaps, could you supply pics if your work? I just took mine out of storage yesterday and found this condition. Dropped the interior lid and letting it dry out.
What bothers me is I sealed it in the fall with the tape.
Thanks.
04-09-2019, 11:12 AM
Condensation has always been a problem with RV's, especially when it's cold outside.
A small space with a lot of warm, moist human activity is science in action.
You need a lot of ventilation to keep it under control.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
04-09-2019, 11:39 AM
The problem here is that the moisture is between the 2 glazed units of the skylight. Yes it has 2 Plexiglas pieces. With moisture between them means the seal has broken.
This is a new unit and so far has not had any human activity in it but thanks for the reply
04-09-2019, 11:47 AM
Ah, ok, a double pane skylight, glad the dealer will take care of it.
04-09-2019, 11:55 AM
My inner bezel was actually sealed with a bead of white silicone bath caulk to the ceiling so I dont have the condensation issue. Maybe you want to go that direction instead of tape. It was also screwed to the ceiling.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
04-09-2019, 12:02 PM
Thanks, mine was screwed in as well. I'll go the caulk route to see if that helps. Thanks again.
04-09-2019, 10:15 PM
After taping mine last year, I agree caulk seal might be the best solution.
