Old 04-02-2012, 09:53 AM   #1
Slide Topper ??
Has anybody with a Freedom Express installed or had the dealer install a Slide Topper?
My question is , is it worth it?
I know it helps keep stuff off the slide roof, and helps with water intrusion during rain , however my understanding is that the Freedom Express has double slide seals which should eliminate leaks. I also have no problem using a small step ladder to check for debris before heading out.
Any other benefits that I might be overlooking?
1 negative for me is that the dealer said its $900.00 installed and I figured if the mfg doesn't install it from the factory, then its not really necessary.
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
pwrplay is offline   Reply With Quote
Old 04-02-2012, 09:59 AM   #2
trudinator's Avatar
If you survey 100 people, 50 will say you need slide toppers and the other 50 will say you don't need them. I'm on the side of the "don't need them." We camp in the woods 95% of the time and usually have to deal with wind. In this instance, debris (small twigs, leaves, etc.) will get under the slide topper. So before bringing in the slide, you have to go up on a ladder anway and clean off the slide underneath the slide topper. Not any different than having to go up and clean off the slide without a slide topper. Other than shedding the acorns being pelted at us from rambunctious squirrels, I don't see an advantage to having them in our neck of the woods. And $900 is waaaay too much to pay to have one installed, IMHO.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 04-02-2012, 10:14 AM   #3
I guess I am of the 50% that say they are a great investment. In 7 years there has been two instances where i had to retract the slides. Both in a very high wind and both at the exact same place on the coast. Having them the slide out areas are cooler in the summer, no direct sun on the slide roof. When I retract the slides there is no water inside from the roof during a rain storm. It is really a personal preference. Some don't like them, usually ones who have not had them, and some love them, usually ones who do have them.
Old 04-02-2012, 04:38 PM   #4
steeleshark2's Avatar
I have a skylight on my slide so I will not install one. Just goto Lowes and get a long handled squiggie to get the excess water off before bringing it in. Actually, I have a ladder, regular water hose and sprayer to clean the top off before I bring it in. No need for a topper in my book.
steeleshark2 is offline   Reply With Quote
Old 04-02-2012, 05:04 PM   #5
It is one of the best investment on your trailer. It is a very good insurance against water leaks and the top of your slide stay clean. No need to climb on a step ladder to clean the leaves etc before you bring it back inside. Go for it and you wont regret.I have seen many slides that leaks in heavy rain and I made sure when I ordered the trailer to have this usefull option.
capucine is offline   Reply With Quote
Old 04-03-2012, 08:18 AM   #6
So it looks like it is about 50-50. I think I'll do without one and see if I have any issues or the 1st year at least. If I need to add one, it doesn't look to hard to install.
Old 04-03-2012, 09:20 AM   #7
My last three rv's first a TT without a topper after a year of heat and water coming in I added one and eliminated the problem. Yes when camping in the wind I did take the extra step to check under it and made sure that I had no hitchhikers under there (pine needles, pine cones etc). On my last two I would not purchase without the topper.
Although it all comes down to preference.
Enjoy the camping.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 04-03-2012, 11:46 AM   #8
trudinator's Avatar
We've never had a problem with water coming in when bringing in our slide.
Old 04-03-2012, 01:30 PM   #9
Me either! This is my 2nd TT in 8 years with a slide and neither had/has a topper with no issues. I guess it's possible if the conditions are right, I just have a lot of other things I could spend $900 on. If you could have got one installed from the factory it's a lot less expensive and might be worth the extra cost.
Len & Cheri is offline   Reply With Quote
Old 04-03-2012, 02:47 PM   #10
I noticed on the slide out on the 292BHDS that it looks to be very well sealed. There looks to be a seal on the inside top ( in behind the trim)of the actual slide out itself that meets the body when its open, as well as 2 (1 inner & 1 outer) seals it looks like on the frame around the opening , but I am just going from memory when I looked at it on the weekend.
So I don't aniticipate any leaking/draft problems, however if after the one year warranty expires, it does start leaking, I'll look at installing one then.
