Originally Posted by boatman22
Bringing up an old thread....does anyone have photos of this seal installed? I can't figure it out to install.... Thanks
These units were made this way at the factory. When we got ours it leaked because of the missing seal. Went back to the dealer and he looked at 6 of the same model and they all were missing this 10cent piece of foam.
Here is a document that shows the foam in place. you can see this when you look under your slide. Don't worry you don't have to remove the slide in the picture, that was an easier way for them to show it. Also be aware that the 2inch seal under the slide is also going to be puckered and you will get water there as well. I have FR send me both the seals and the foam. Replace the seal without pucker and installed foam and all is good. Damn shame you have to spent so much time working on something that cost so much.
Anyway see the following and I hope it helps.
