Originally Posted by Scrapper
If it is just a cut you might use seam sealer for vinyl flooring. If it is a corner tear use contact cement under the edges and use a roller to press it down, then seam sealer where the edges come together after the contact cement sets.
If you are going to use glue under the vinyl,,, be careful it does not osse up into the cut !!! Seam Sealer is defiantly the best thing to top it with,,, some super glues can yellow,,, Seam Sealer will not !!! You may have to find a store that sells floor covering supply's !!! Maybe the Big Box stores do ???
