Originally Posted by Pmixmaster
so basically it runs direct back and if you plug your panel in its a direct feed back to trickle charge did i understand you correct i would just plug and ply so to speak?
Plug and play possibly if you purchase the Zamp solar kit.
If you buy just a panel, you have to have some kind of charge controller or at the very least a diode in the circuit to keep the panel from backfeeding during non charging times.
Think of the 'solar ready' port as nothing more than having access to the 12v battery connections without having to access the battery itself.
EDIT: Here is a link to Zamp's web site.
It will give you an indication of what to expect.
**ZAMP**
