Old 04-13-2019, 07:25 PM   #1
swampdonkey772's Avatar
The quick connect saga
So after much delay and frustration I finally got my propane quick connect done. Initially I was just going to T off the distribution block but couldn't break the connection. Then I was going to run rubber hose from the regulator to the back but no one around carried that size. So I finally decided to run galvanized pipe from the regulator to the back. Here are pics of the installClick image for larger version
ID:	201629Click image for larger version
ID:	201630Click image for larger version
swampdonkey772 is offline   Reply With Quote
Old 04-13-2019, 10:13 PM   #2
Very nice. Looks like a good bit of of work. Did you hook it up your implement of cooking to try it out?
Every time you use it you'll think, yeah, I built this. Nice job.
Skip12 is offline   Reply With Quote
Old 04-13-2019, 10:14 PM   #3
Galvanized on gas pipe?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-13-2019, 10:15 PM   #4
Yeah i hooked the 17" Blackstone up, gets good and hot. Now just to figure out how to switch my BBQ to low pressure and I'll be all set
Old 04-13-2019, 10:16 PM   #5
Yep that's what the propane guy recommended.
Old 04-13-2019, 10:19 PM   #6
What bbq do you have? I left my Roadtrip at home for the first time in ~20 years and survived pretty well with a 22" Blackstone for a week. Still have some learning to do...
Old 04-13-2019, 10:44 PM   #7
B and B's Avatar
Should be black pipe. The galvanized pipe will flake and plug jets in the appliance.
Google it, not approved for use due to what I have said above.
Old 04-13-2019, 10:45 PM   #8
I don't know the maker, I bought it from Walmart a few years ago. I probably will drop it and rebuild the outdoor kitchen in the next few months. This trip will be a good indication if I drop the BBQ all together. I still have the Treager in the 5er
Old 04-13-2019, 11:48 PM   #9
I wouldn't use it. Not allowed and would fail an inspection if used in a home.
Old 04-13-2019, 11:52 PM   #10
Some places it's not allowed, some places it is. And this is a travel trailer not a home and it's not going to be underground.
