Old 04-02-2015, 04:41 PM   #11
Send a message via MSN to Tiggerdad
I agree
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 04-02-2015, 10:37 PM   #12
farmncamp's Avatar
So I might not be the best at describing what I was doing.
I was checking the play in the bearings by lifting the tire off the ground. One tire had play, so I needed to remove the lug nuts. Had the problem with clearance between the socket / rim here. Used a 22mm 12pt socket to get them off. The spindle nut used a socket around 1 3/4". I got a 1/4 turn out of it and fixed the original issue. All should be fine now.
Main point I wanted to get across is make sure your tire changing socket fits properly.
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
Old 04-03-2015, 02:30 PM   #13
(Dry Huunday)
DreiHunde's Avatar
And that is a good tip, thanks!
Better to check now than find out later...on the side of the interstate!!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
wheel
