Old 04-01-2015, 11:12 PM   #1
farmncamp's Avatar
Tight wheel rim / nut clearance
I carry a set of wrenches with me in the event of a blowout or flat for our 360IBL. They worked fine with my old trailer. Today I was checking the wheel bearings (had to tighten 1) and realized all the sockets I carry were too thick. They would not fit inside the space between the rim and nut. I had to purchase a 22mm 12 point socket to get the tire off.
Just wanted to call this to attention. I assumed my old tool kit would work, but I was wrong.
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
Old 04-02-2015, 05:28 AM   #2
Learjet's Avatar
had the same problem on my old trailer with my 06 Series HiSpec rims...needed a thin wall socket.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 04-02-2015, 06:18 AM   #3
Proper Socket for (Lug Nuts) would be a (6 point) with OD to fit Bore! Youroo!!
Old 04-02-2015, 06:45 AM   #4
And the inside to fit the nut!
Old 04-02-2015, 02:27 PM   #5
Send a message via Yahoo to jallen02
Wheel bearing should be a little loose, it will tighten when it gets warmed up, (after a few miles).
jallen02 is offline   Reply With Quote
Old 04-02-2015, 02:30 PM   #6
If you jack the wheel up and can get over 1/16" movement in the top or bottom of the wheel, IT IS TOO LOOSE!
Old 04-02-2015, 03:37 PM   #7
Send a message via MSN to Tiggerdad
Believe he was referring to the actual lug nuts and not the spindle nut.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 04-02-2015, 03:46 PM   #8
IF that is true, he is definitely "out to lunch" Lug nuts should never be loose and definitely will not tighten after a few miles.
He specifically stated "Wheel bearings" as you quoted.
Old 04-02-2015, 04:06 PM   #9
Yeah-The OP said wheel bearings and it appears to me that he qualified that statement by saying he purchased a 22 MM socket, That size would never fit the spindle nut that tightens the bearings.
Jallen was referring to the wheel bearing nut and my first thought was wheel bearing nut also until he mentioned the 22 MM socket.
Old 04-02-2015, 04:13 PM   #10
I don't think anyone would mean a lug nut will tighten after a few miles. JMO.
Old 04-02-2015, 04:41 PM   #11
I agree
Old 04-02-2015, 10:37 PM   #12
farmncamp's Avatar
So I might not be the best at describing what I was doing.
I was checking the play in the bearings by lifting the tire off the ground. One tire had play, so I needed to remove the lug nuts. Had the problem with clearance between the socket / rim here. Used a 22mm 12pt socket to get them off. The spindle nut used a socket around 1 3/4". I got a 1/4 turn out of it and fixed the original issue. All should be fine now.
Main point I wanted to get across is make sure your tire changing socket fits properly.
Old 04-03-2015, 02:30 PM   #13
(Dry Huunday)
DreiHunde's Avatar
And that is a good tip, thanks!
Better to check now than find out later...on the side of the interstate!!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
wheel
