Originally Posted by ysidive
I have a coachmen freedom express 281rlds. GVWR 7600 lbs.. Tires that came on trailer are 205/75R14C. Seems that a tire of this size is rated at a maximum load of about 1760 lbs Seems that these tires are grossly underated for the GVWR stated. I am thinking about upgrading to 15" wheels and tires 225/75R15C...
Any input would be appreciated...
As the others have said subract your tongue weight from the GVWR. You could simply keep the same size but step up to load range "D" which will give you a max load capacity of about 2150lbs/tire if I remember correctly. You would need to be sure your wheels could handle the higher psi requirements for the tires you purchase.
Edit: Reading the post above the "D" load range is not 2150lbs.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
