Old 11-23-2015, 08:09 PM   #1
Tires
Anyone have recommendations for tires for my apex 259bhss. 100 miles on my way home with my brand new unit and I have a blowout. Cheap tires they put on these rigs.
Firemedic is offline   Reply With Quote
Old 11-23-2015, 09:42 PM   #2
dcheatwood's Avatar
Not sure what size you have but many here will recommend going to Goodyear marathons or maxxis and up one level on load capacity if you can. I went from load range C to load range D. I've have 3 blowouts and one flat from internal belt separation on original tires. They are junk. Also, consider reporting the blowout.
2018 Forester 3011 DS
Old 11-23-2015, 09:59 PM   #3
Blackhat6mike's Avatar
Originally Posted by dcheatwood View Post
Not sure what size you have but many here will recommend going to Goodyear marathons or maxxis and up one level on load capacity if you can. I went from load range C to load arrange D. I've have 3 blowouts and one flat from internal belt separation on original tires. They are junk. Also, consider reporting the blowout.
X2 on reporting the blowout to the NHTSB. This is the only way we can get the junk off the roads and just maybe save some lives. Also, X2 on upping the load range ATLEAST one range. Two if possible. It's your life you are betting with.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
tire, tires
