05-29-2015, 09:55 AM
Toilet
I've got an Apex 300BHS. Paper seems to be getting stuck just below the flapper. Flushing water does not push the paper through. Any suggestions? Also last night a toothbrush fell straight through as I had the flapper open trying to get the paper through. Is this plumbing a straight shot to the black tank or is the toothbrush now lodged somewhere? I can't see it.
05-30-2015, 10:25 AM
I had a similar episode last weeked on our 320BHDS and I resolved the "issue" with a long stick we found in the woods. With a little poking and pushing I was able to move the "stuff" to the back and right, once the clog was gone it hasn't happened since. It does not appear to be a straight shot to the tank, it would make too much sense to have it that way.
AJ Kirkpatrick
2003 Dodge Crew 3500 Cummins
2015 Coachmen 320BHDS Liberty Edition
05-30-2015, 10:31 AM
Left Coast
Need to use more water in bowl before and at flushing time............on mine, if you slightly step on flush petal, you can add water and not open valve to flush...suggest not re-using toothbrush.
05-30-2015, 10:33 AM
I agree with the need for more water.
05-31-2015, 03:17 PM
Lots of water required in the bowl, mine is always getting stopped up just below the flapper. Grandkids just can't seem to understand to use less TP!
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
06-01-2015, 09:09 AM
(Dry Huunday)
I agree with the "not re-using the toothbrush"
and the lots of water advice as well
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
06-01-2015, 09:36 AM
A little aggravating, but we put NO paper in the toilet. Eliminates most all black tank issues.
06-01-2015, 10:21 AM
Left Coast
Why not.....with the additives that are out there, paper disappears in short order if there's enough water to activate the chemicals.... using a clear elbow and a tank flush, I've not seen any paper problems..... besides, gives you something to watch while the boring drain process is going on.
06-01-2015, 10:25 AM
More Water more water more water!
If your doing number two the bowl should be half full or better before flushing.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
06-01-2015, 10:35 AM
Left Coast
TURBS
2011 32bhok Sabre
Or, use the parks out house....love those 95 degree days!.... Glad my AC works. Must of been a cowboy in days gone by.
06-01-2015, 10:49 AM
Yup, more water. And toilet paper dissolves in water quite rapidly, no matter WHAT kind of paper you use. Even with the GEO method, paper dissolves. You don't need chemicals for this to happen. No flushable wipes, though! I did an experiment and put a wipe in a bowl of water for 30 days and it didn't break down at ALL. Even though they say they're flushable, they'll clog your RV toilet in a heartbeat!
2012 Rockwood 8293RKSS
06-01-2015, 11:01 AM
Left Coast
Must of been a re-cycled product......from a plastic bag!
06-01-2015, 11:26 AM
Our rule for flushing time is:
3 for pee, 6 for shyts..
Count to 3 or 6 with the flush valve open accordingly.
06-01-2015, 11:35 AM
Yep we fill up the bowl with water for #2 and only use RV TP...never had any issues. (And always fill the black tank full before draining.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
06-01-2015, 11:31 PM
Try using more water with each flush. We also use a powder substance at the beginning of each trip to help break down paper. Also, one trick is to use the leftover ice from your cooler in the toilet to help push substances through the black tank upon emptying. Good luck.
07-13-2015, 01:54 PM
I just noticed this last trip that water won't stay in the bowl (it used to). It drains out after a few minutes. I always made sure water was in the bowl (3 girls and lots of TP). The flapper seems to be closed all the way. Any ideas?
2015 Keystone Cougar 29ROB (wait, can I still be on here??)
TV: 2016 Ram HD 6.4 Hemi 4.10s dual exhaust
07-13-2015, 02:36 PM
Yes with water off, clean the flap and gasket throughly with soft cloth and detergent. Lubricate the gasket with rubber/neoprene friendly grease. I use silicone. Not a permanent fix but should last awhile. Keep a seal of water in the bowl when possible.
