08-24-2018, 04:40 PM
Toilet Problem
2017 Coachmen Chaparral Lite 5th wheel. Has porcelain toilet. Will not hold water in bowl for short time period. Can see black ring where it appears to seal.
Can I replace the seal or must it go into a dealer? Also, how would I find the model to get the part?
Thank you for any assistance.
Rick
08-24-2018, 04:57 PM
Search this site with your brand of toilet and seal replacement and you will finds lots of input
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
08-24-2018, 05:03 PM
Most toilets have to be removed to replace rubber seal. Before doing that put on gloves and rub vegetable oil all around top and bottom of seal while holding open. Sometimes seal dries out from heat
08-25-2018, 10:04 AM
Rick
IMO, your unit is to new for the seal to dry out, what can happen is the seal slides to one side which will create the problem your talking about. There is a y tube on it and how to reposition it, I would try that first...
Coachmen M/H
Concord
2018 / 300 DSC
08-25-2018, 10:26 AM
Kanadian Kamper
rcostello.....
It would help if you tell us the make and model of the toilet. Telling us your motorhome model doesn’t help us, because manufacturers often change components within the motorhome like what you’re questioning.
Ken and Terry
08-25-2018, 10:31 AM
Originally Posted by kenandterry
rcostello.....
He said he didn't know the model or could he find it, per the OP a couple of post ago.
Coachmen M/H
Concord
2018 / 300 DSC
08-25-2018, 10:35 AM
Kanadian Kamper
Guess I missed that one.
My make and model are labled at the back underside of toilet. You need a mirror and flashlight to see it, or remove the toilet to turn it upside down. However, I upgraded ours and have the owners manual.
All toilets are not created equal
Ken and Terry
08-25-2018, 10:51 AM
Just as confused as you
If you bought the TT new there should be a booklet or sheet for the toilet in the papers given to you. It should be listed on the build order sheet along with the model and serial numbers. I got a Appliance Information Sheet from my dealer listing everything installed in/on my TT. It even listed the slide toppers we had the dealer install. Otherwise you will have to get on your knees and look near the flush valve or under the back part of the toilet. Use a smartphone front camera to help locate it, then take a picture of the sticker. On my old SOB TT the label was up under the back side, even standing on my head I couldn't see it. The phone camera came to the rescue.
Richard & Jill
08-25-2018, 02:05 PM
rcostello.....
The OP said they have a 5th wheel in the first post and posted it in the TT/5th Wheel section.
08-25-2018, 02:18 PM
first get some plumbers grease and grease the seal in place . if that doesn't work then you'll need to replace . then it depends on brand of toilet . most likely it's a thetford aqua magic or dometic series 310 320 or?
