Old 05-25-2014, 07:26 AM   #1
Rico1971's Avatar
Top of Door Rubs the Awning
Fellow Apex 259BHSS-ers....
Anyone else noticing that the top of the door rubs against the awning? It's really only brushing up against it, but I'm still concerned about wear over time. Is this something that can be adjusted?
Name:	ImageUploadedByForest River Forums1401020752.385504.jpg
Rico1971 is offline   Reply With Quote
Old 05-25-2014, 07:31 AM   #2
Ford Idaho's Avatar
Are the arms locked?
One black knob on each arm.
Old 05-25-2014, 07:34 AM   #3
Go to Camping World and get one of these.
Old 05-25-2014, 07:43 AM   #4
If all else fails retract awning just a Small amount,then it will NOT rub! Youroo!!
Old 05-25-2014, 07:48 AM   #5
Rico1971's Avatar
Yep. Arms are locked.
Thanks for the other suggestions!
Sitting here with my coffee and noticing the angle of the arms...is the angle of that lower bar normal? I tend to get paranoid and could just be creating issues... Lol. :-)Click image for larger version
Name:	ImageUploadedByForest River Forums1401022071.915252.jpg
Old 05-25-2014, 07:54 AM   #6
Its fine,keep drinking your Coffee! Youroo!!
Old 05-25-2014, 07:56 AM   #7
Did you (Bump) the (Retrack Switch) to give more clearance? Youroo!!
Old 05-25-2014, 07:58 AM   #8
Oklahoma Proud
MillerTime's Avatar
Just push the lower awning arms out some and retighten, and you're awning should go up enough to clear the door. Or roll awning up a couple inches.
Our last 5er was the same way. We couldn't have the awning that far down w/out the door rubbing.
Old 05-25-2014, 07:59 AM   #9
Ford Idaho's Avatar
If you unlock then the awning it should raise just a bit, do so easy and hold on to the arm as you twist the knob.
Old 05-25-2014, 10:18 AM   #10
Retired Trucker/43 years
Noneyerbusiness's Avatar
Dometic will advise you NOT to lock those arms. Their design, (which I detest!), is to allow the awning to move about in the wind. Those pneumatic rods are supposed to return the awning to the proper position.
How do I know this? Close to $500.00 to replace the tubes. A gust of wind hit the awning while I had the arms locked. No flex .... except the arm it's self, which committed suicide.
"IF" you choose to lock them, then you MUST tie them down to prevent movement.
As to the original question, on my Windjammer the door also drags the bottom of the awning. If I ever have to mess with it again, I will replace it with a manual awning.
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
awning, door
