02-26-2017, 12:40 PM
Truck tires
Anyone have any insight to which tire (265/70/18) would be best for towing fifth wheel? Im more interested in weight verses longevity
02-26-2017, 09:28 PM
I don't even want to reply. need more info. what truck? rim size? what trailer? pin or hitch weight? you will need to figure out how much weight you need to carry and from this you can figure out the tire load range required. then you can start looking for tires that meet your specs. also, in your post you mentioned a tire size but it was not an LT tire size? do you need LT tires? will the rims carry the psi the new tires may require?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
02-27-2017, 10:50 PM
Well I thought I was in the "fifth wheel" forum so that answers your hitch or pin weight question and I thought I gave info on tire size and actually all Im really asking is who has had the best luck with what tire meaning brand of
02-27-2017, 10:51 PM
And also if you didnt want to reply why did you then?
02-28-2017, 09:18 AM
What is wrong with the OEM tires? I assume you have 'E' rated on your 2500. Each brand should have the same load rating in that size.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
02-28-2017, 09:31 AM
Been towing 5th wheels for the last 27 years.
Michelin has always been my choice on the tow vehicle.
02-28-2017, 09:40 AM
Who Dares, Wins
I've always liked Cooper discovery at3s.
2015 Chevy HD D-Max
2022 Impression 315MB
02-28-2017, 08:36 PM
Yes thats true but they have over 50,000 on them and manufactures always use a lesser brand tire then I would normally use so Im just wondering whos had what brand with what kind of luck with them
03-01-2017, 11:24 AM
You don't say what your 'lesser brand' tires are but it appears they have served you well.
03-02-2017, 12:47 PM
I've always been interested in "cost effective" and "longevity". I used to tow often, long and heavy when I was still racing. My "goto" tire for a long time was Firestone Transforce HT. I have 17 in wheels on my dually (LT245/75/17 E) These tires have a good highway tread and did very well towing a 20,000 lb enclosed 2 car hauler 25,000 miles a year.
I was told the Transforce was being discontinued the last time I bought tires so I switched to Yokohama Geolander A/T-S. These were in the same price range ($150-160) as the Firestone and had better ratings on TireRack. I've only had them since November and have only towed 2 or 3 times, but I like them so far. You'd have to check if they come in your 18' size.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
03-02-2017, 01:26 PM
I like my Toyo tires. I've got over 70k miles out of the Toyo A/T II's that I've got on my 2007 F150, will probably have close to 75k on them in April when I replace them with the same thing. I put Toyo HT's on my 2013 F150. Both are rated the same (E maybe?) Both are made in USA, even if they sound Japanese.
Don & Kim
Willow Spring, NC
2012 Rockwood Ultra Lite 2604
2013 F-150 4x4 EB
03-02-2017, 07:47 PM
Actually you are in the General Travel Trailer & Fifth Wheel Discussion Coachman forum.
That said,I run Michelins on the front and Coopers on the rear of my dually.
They both seem to be wearing well, 17" tires. I'm about 2540 on pin weight.I saved about $300 going this way over the Michelins all the way around.Which ones wear the best will be the next set I buy.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
