Old 05-26-2018, 07:52 AM   #1
TV 12 volt wiring
I have a new 2018 Viking 17 ft trailer. It did not come with a TV so I have mounted one and it works well when plugged into shore power. Now I would like to be able to run it off the battery when there is no power but I don't have any 12 volt receptacles. The TV has a cigarette lighter type plug so I would like to install a 12 volt receptacle for it. Any suggestions on where to find the best wire to tap into?
Thanks,
New to camping, as you can tell.
stringer is offline   Reply With Quote
Old 05-27-2018, 09:37 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions and answered. I would think you could run a wire direct from the battery or off any of your interior lights.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-27-2018, 10:05 AM   #3
cavie's Avatar
If you run off a light the light would most likely have to be on. That's too much to ask the installers feed at the light and run switch legs to the switches. That's not (a to b to c). that's (a to c to b). Don't confuse the help. Their already confused>
You can tap off any 12 volt that is not SW controlled. a TV is not much of a load. But I am confused. If your TV is 12 volt it should work whether it is on shore power or not unless you have your battery turned off.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-27-2018, 10:28 AM   #4
Is your tv close to the converter? If so tap into a circuit there, or install a new circuit If there is an open 12 volt space. Install a 20 amp fuse and mount a lighter socket nearby.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 05-27-2018, 10:42 AM   #5
SeaDog's Avatar
I don't understand your statement. Believe it or not one side of a switch has to be hot even in an RV. I should have included the word circuit. as in interior light circuit.
Retired Navy
Old 05-27-2018, 05:34 PM   #6
Sorry that I seem to have posted this in tents and pop ups...I know as much about forum posting as I do camper wiring. The problem is the outlets in the camper only work when plugged into shore power and there is no 12 volt receptacle. So I need to install a 12 volt receptacle to plug in to. I am near the converter so I look for a wire to tap into there. Thanks.
Old 05-27-2018, 05:38 PM   #7
The first question is, where in the camper do you want to place the TV? Apparently, you have used an adapter to convert shore power to 12 volt?
PenJoe is offline   Reply With Quote
Old 05-27-2018, 05:48 PM   #8
Check if there is an unused 12 volt slot at the bottom of the converter. You would then just need to add a fuse.
Old 05-27-2018, 05:50 PM   #9
cavie's Avatar
Most of the time you bring the hot and neutral to the switch then wire up to the light. But you can also bring it to the light 1st than down to the switch on the white and back to the light using the black as a switch leg. leaving the neutral at the light. White becomes a hot wire for that short distance. That's how amatures get hurt because they don't know to look for that. They see a black and a white on a switch and don't know what to do. Thankfully I haven't seen or heard of it done in RV's yet. Don't get me started on 3/ways.
Old 05-27-2018, 05:50 PM   #10
bikendan's Avatar
Is your trailer NOT a popup?
You didn't post the model number, you just posted the length. You also don't have the info posted in your profile.
If it's a TT, I can move it to the appropriate area.
Equalizer WDH
