Old 01-10-2014, 09:21 PM   #1
pkurek's Avatar
TV mount
Anybody mount a flat tv wall mount on the back wall btw the bunks above the cabinet on a 292 bhds? Can it be done? It is for a 19" lcd.
Paul, Dawn, Brennan & Blake Kurek
2013 Coachman 292BHDS
2005 F150 Lariat SuperCrew 4x4
1 spoiled lab and 1 even more spoiled boxer
pkurek is offline   Reply With Quote
Old 01-12-2014, 08:12 AM   #2
1atalbot's Avatar
I was looking at that area as well, but typically they have a sticker on the wall indicating it's ok to mount the TV in a certain spot. I am planning to just lay the TV on a bed during travel. Just one more thing to have to do!
1atalbot is offline   Reply With Quote
Old 01-12-2014, 09:58 AM   #3
pkurek's Avatar
right now i put it in the styrafoam edges it came in the box and set it in the storage compartment between the beds.
Old 01-12-2014, 07:45 PM   #4
Scubanut's Avatar
[QUOTE=pkurek;524014]Anybody mount a flat tv wall mount on the back wall btw the bunks above the cabinet on a 292 bhds? Can it be done? It is for a 19" lcd.[/
The dealer actually added the bracket for a flat wall mount. The problem with that is if your on the bottom bunk you can't see the TV. I swapped out the flat mount for a swivel mount. I added a buckle strap to secure it while traveling. It has worked fine for last season and the grand kids are happy they can all watch the tv.
Scubanut is offline   Reply With Quote
Old 01-12-2014, 09:09 PM   #5
pkurek's Avatar
yea, that is what I want. A telescoping wall mount that tilts so the bottom bunk can see. right now we prop the back of the tv fwd so the btm bunk can see it clearly.
Old 01-12-2014, 09:10 PM   #6
pkurek's Avatar
Scubanut, do you know how they mounted it?
Old 01-12-2014, 09:14 PM   #7
Scubanut's Avatar
TV mount
They used a modified flat bracket that was not really designed for the location. I think there was either 4 or 6 1.5 inch screws mounted directly to the back wall. When I took it off I used the same location to attach the mount is replaced it with. I used 6 screws to attach and it is holding good.
I added. 24 inch LED TV.
Old 01-12-2014, 10:01 PM   #8
pkurek's Avatar
thanks for the info.
Old 02-05-2014, 10:35 AM   #9
48fan's Avatar
if u only have the shelf to set the tv on can u mount to that shelf thought about sandwiching 2 pieces of plywood one on top off shelf and one on bottom of shelf and using nut and bolts wanting to mount a 20 inch with swivel mount would this work
48fan is offline   Reply With Quote
Old 02-05-2014, 03:36 PM   #10
1atalbot's Avatar
TV mount
Can you post some pics of this setup, as now you have my interest. I was look to mount a bracket on front TV so you could bring it out a few inches in order to leave your bedroom doors open while the TV is on in the bedroom on the 292.
mount, tv mount
