Old 03-20-2019, 09:03 PM   #1
Ktsmom's Avatar
Question TV Mounting?
I recently purchased a 2017 Coachmen Catalina 251RLS. I want to place a TV on the wall where the floorplan shows "TV/entertainment" area. Does anyone know if there's a backer-board in the wall that will hold a mount? The TV is a 40inch and I think it weighs about 8-9lbs.
Ktsmom
Ktsmom is offline   Reply With Quote
Old 03-20-2019, 09:12 PM   #2
Usually there is a little sticker on the wall where you'd put a TV mount. Mine had a sticker and there was a 24x24 wood backer inside the wall. Think my tv is a 42" and the mount is very solid.
TheWolfPaq82 is offline   Reply With Quote
Old 03-22-2019, 09:18 AM   #3
Mine had a sticker but the actual board behind the panel was about 8 inches higher. Knock knock!!
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 03-22-2019, 09:35 AM   #4
My TV backer seems to be a piece of sheet metal.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-22-2019, 09:42 AM   #5
I wonder if they just look for scraps they have laying around to use as backers in the wall.
Old 03-22-2019, 10:28 AM   #6
Misfit Adventures
Misfit011's Avatar
It should be more then stable I'm hoping to check that out in my trailer today if I can get threw the mud . Lol
Misfit011 is offline   Reply With Quote
Old 03-22-2019, 10:32 AM   #7
A stud finder is your friend in this instance. I was lucky in that the entertainment center and the bedroom shared a wall and the pocket doors allowed me to look inside the wall to locate support for the bedroom tv. A stud finder and an oversized cable hole helped me locate a "stud" for the swing arm tv mount. I posted on the adventure: TV mount point in 243 RBS
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
mawilson is offline   Reply With Quote
Old 03-22-2019, 10:53 AM   #8
Good advice above for sure.
Lots of different mounts available here:
https://shop.ramco-eng.com/collections/moview-mounts
I ordered on of the mounts early in the week and it was delivered yesterday.
Just make sure that your screw length is short enough. The walls are pretty thin.
Bob
2018 Rockwood Ultra Lite 2902WS Travel Trailer
HappyTrav is offline   Reply With Quote
Old 03-25-2019, 06:48 AM   #9
Ktsmom's Avatar
Thanks!
Thanks to everyone for the valuable advice! I did find the backer board. Took several "knocks" but I got it. I will get a stud finder! LOL - maybe that will help me in more ways than one!
Ktsmom
mount, tv mount
