Old 02-17-2019, 05:14 PM   #1
underbelly patch!! New idea
I think I just came up with an idea to cut any size hole you want in the Coraplast (is that what its called?) And put it back together like new and just put tape on the seams. Really got excited about this but I want to try it first. Another idea which I'll share now is go buy the digital cameras that have about a 3 ft snake on them with the camera and a light in the tip. Electricians use them to look in walls. You can just poke it thru a small hole in the area you are looking for a problem. Lowes ,,,Home Depot sell them pretty cheap. Have a hand held led screen on them. Film at eleven.
Lee Pedrick is offline   Reply With Quote
Old 02-17-2019, 05:43 PM   #2
If you cut a hole in the coroplast, rather than just repairing with tape only, consider this.
Cut some strips off a piece of 1/4" plywood. Place strips the inside of the coroplast with about half of he strip extending into the opening, along the sides.
Secure with some short drywall screws. Place piece you cut out in the now "framed" hole and secure with more short drywall screws. This creates a structurally sound patch and if you want to seal it just cover seams with some aluminum tape. Using this method you can actually open up a fair sized window, enough to actually do some work through if necessary. for more strength when re-securing panel just place the strips diagonally across each corner, using drywall screws to secure both strip and panel being re-secured.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-17-2019, 07:13 PM   #3
titan mike nailed it with the plywood strips. you can also use sheet metal roof flashing and use self tapping sheet metal screws to secure it. clean the coroplast with denatured alcohol and then put some tape over the cut to seal it. i found some tape on the internet called underbelly tape and it holds to the coroplast very well.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 02-18-2019, 08:53 AM   #4
Great ideas! My thoughts were about the holes in the material. The corrigation holes,,, sliding properly sized dowels in them and hold the patch up and slide the dowels in to them,,use needle nose plyers to help slide them in then tape the finished hole. this might work well with smaller holes. One thing I have decided,,,, I'am NOT ripping it all down. I looked under there,,,too much work!!
Old 02-18-2019, 09:33 AM   #5
I used a one hole punch and small zip ties. On top of the patch gorilla tape.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 02-18-2019, 10:02 AM   #6
Head Rambler
I've used Gorilla tape to repair Coroplast and if you clean both surfaces well, it holds extremely well. On one RV we had, I repaired an opening of about 1' by 2' and it was still solid after 5 years when we got rid of that unit.
I like the idea of framing the opening if it's something you're going to have to access periodically, but if the possibility of having to access that place is remote, then I'd just use Gorilla Tape.
Gotta go campin!
Old 02-18-2019, 10:06 AM   #7
If you do cut a hole, simply cut on three sides and leave the forward edge as a hinge.
Refasten the other three sides with your favorite method described.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 02-18-2019, 01:57 PM   #8
Some great info on re-fastening the coroplast here.
Jumping back to the OP's other topic about the camera...
Besides the camera he mentioned, check out USB borescope / endoscope cameras that hook to your smartphone (Android especially; I imagine someone's got something for iPhone)
I have one that I use for automotive stuff, etc...works very well, and they're generally sub-$20 on Amazon.
They may not have the semi-rigid gooseneck on them (at least the cheapies don't), but they're definitely more portable, and very likely cheaper. And of course, you can take pics and videos with them & save to your phone.
Reprise is offline   Reply With Quote
Old 02-18-2019, 02:08 PM   #9
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Reprise, x2 on the smart phone cameras. I got one with a 35’ cable. I tape the camera to either a fish tape or push-sticks. Comes in really handy when doing mods in the RV, car or around the house. You can look into the walls, ceiling or belly to run wires or looking where it is OK to drill......or to find the XXX’n bolt I dropped in the engine compartment......lol!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 02-18-2019, 02:49 PM   #10
There is a tape available to repair the Coroplast, and should be available from your local RV dealer. If you have a good relationship with your dealer, they should be willing to sell you any length you need, you shouldn't have to buy a whole roll.
tomrob1161 is offline   Reply With Quote
underbelly
