Old 07-01-2019, 01:49 PM   #1
Updating the Kitchen Faucet
Hi,
So I bought a new kitchen faucet from Home Depot to replace the flimsy one that came on my Freedom Express. But I am having a hard time installing it. The faucet comes with 3/8" fittings and from what I can tell the fitting on the TT is 1/2" so I need a conversion fitting for it. However I have not been able to find a 1/2" to 3/8" male to male threaded nipple for it.
For those that have replaced your faucets, did you have the same measurements and were you able to find the right parts? Am I missing something else with it?
Thanks,
Mike
Draggo is offline   Reply With Quote
Old 07-01-2019, 05:17 PM   #2
Depending on what the connections look like, there is probably something out there that will work to convert.
option 1
option 2
1994 Toyota Land Cruiser
2002 Lexus LX470
2018 Coachmen Clipper 17BHS
baggar11 is offline   Reply With Quote
Old 07-03-2019, 06:54 AM   #3
Thanks for the response but unfortunately those won't work. I need a male to male fitting for it. Although I hadn't thought about a hose like that so maybe I'll have to see what I can find.
Old 07-03-2019, 07:03 AM   #4
I bought male to male fittings at my local ACE hardware store along with new lines to connect the plumbing and new faucet works great
JBFah is offline   Reply With Quote
Old 07-03-2019, 01:16 PM   #5
D W
D W's Avatar
3/8" . Why not just return it and get a fixture with 1/2" connections and be done with it?
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 07-03-2019, 03:09 PM   #6
I had the same issue installing a new faucet in my parent's kitchen, old faucet was 1/2" IPS, new faucet expected to be connected to a 3/8" flare male fitting. I cut the PEX and used a pair of sharkbite to 3/8" flare quarter turn shutoff valves to make the final connection. Easy, and now there are reliable turn-off valves in place.
https://www.homedepot.com/p/SharkBit...00LF/202270613
You don't mention if the faucet input is rigid or flex lines, or whether the unit side is PEX all the way to the 1/2" or if there's flex there and something different further upstream. Those details might suggest other options.
jjkd is offline   Reply With Quote
Old 07-03-2019, 03:31 PM   #7
3/8x1/2 pipe nipples aren't all that hard to find. Even my local TrueValue has them in stock in brass. You could also use a 3/8 nipple plus a 3/8x1/2 bushing to get to the same place. Try this:
mcmaster.com/5485K33
Photo Lab is offline   Reply With Quote
Old 07-03-2019, 08:53 PM   #8
rlh1957's Avatar
Could be a reducing fitting or it may be in the form of a hose with different fittings on the ends.
But it can be done and many change to residential faucets with only a few modifications.
Usually hardware or big box stores can help you match it up.
Check on return policies in case you have items purchased you don't need.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 07-04-2019, 07:27 AM   #9
Late to the game here, but the easiest thing to do would have been to just buy two 1/2x3/8 push-on shutoffs. Cut the PEX, push the new shutoff onto the PEX, then connect the 3/8 from the faucet to the shutoff.
Bruce
Old 07-04-2019, 04:45 PM   #10
DaGrinch's Avatar
Yep. Quarter turn Sharkbite fittings did wonders. ....
ID:	208955Click image for larger version
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 07-25-2019, 06:39 AM   #11
Finally resolved my issue. I had decided to go with new Sharkbite values so I could get the correct fittings but when I asked a friend that does some plumbing work about it he said he's stop by and take a look at it. He had all the crimpers and everything to cut the pex and put a valve on using a crimp so that's what we did. Works great.
faucet
