Here is a shot of the old and new:
Finally, here is a shot of the new wheels and tires crammed in the wheel wells:
One thing I did't think about is that the center caps that came with the Sendel wheels would not fit due to the axle sticking out too far. I just reused the old center caps and I'm happy with they way they look.
I did have to trim a little material on the plastic fender skirts just to be safe, but it is in a location you can't see unless you are laying on the ground looking up.
All in all I am very happy with how this turned out. I now don't need to worry with loads on the tires since these are rated at 3042 lbs, much better than the 2540 lbs the old 15" D rated ST tires had.
