I did the same thing you did, tried to set up my hitch beforehand. I ended up changing it like 3 times to get it right. I also just towed it home with a standard adjustable hitch because I couldn't get it set up right in the rv parking lot. Way easier to take your time without any pressure.
So my advise, don't put it together until your are there, or just tow it home with a regular hitch and set it up later.
I have the 21bh version of your camper (viking and clipper are the same thing) and didn't have any sway without a wdh and I towed mine from over 300 miles away. Don't know what you are towing with but that is a 3000 lbs camper, pretty much anything should be okay without a wdh for the short term.
By the way, my clipper was pretty high at 21" hitch height I believe. I thought it would be much lower. I have no idea it the 17 and 21 are the same.
Good luck
2019 Coachmen Clipper 21bh
2006 Chevy Silverado 1500 4x4 5.3
