Old 06-08-2019, 05:21 PM   #1
Viking 17bh hitch height
Picking up our first camper next week. Can anyone tell me what the hitch height of the Viking 17bh is when level. I want to get my ball hitch set up on my WDH be I pick it up.
shaky86 is offline   Reply With Quote
Old 06-08-2019, 09:26 PM   #2
Big Sky KLX's Avatar
I did the same thing you did, tried to set up my hitch beforehand. I ended up changing it like 3 times to get it right. I also just towed it home with a standard adjustable hitch because I couldn't get it set up right in the rv parking lot. Way easier to take your time without any pressure.
So my advise, don't put it together until your are there, or just tow it home with a regular hitch and set it up later.
I have the 21bh version of your camper (viking and clipper are the same thing) and didn't have any sway without a wdh and I towed mine from over 300 miles away. Don't know what you are towing with but that is a 3000 lbs camper, pretty much anything should be okay without a wdh for the short term.
By the way, my clipper was pretty high at 21" hitch height I believe. I thought it would be much lower. I have no idea it the 17 and 21 are the same.
Good luck
2019 Coachmen Clipper 21bh
2006 Chevy Silverado 1500 4x4 5.3
Big Sky KLX is offline   Reply With Quote
Old 06-08-2019, 09:47 PM   #3
Fluffywhitedogs's Avatar
I can measure the hitch on my Clipper 17bh tomorrow if it helps, but it your unit new or used? I have a 2015 with 13” wheels, and I think the newer ones might be 14”?
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 06-08-2019, 09:52 PM   #4
Used 2017 13" wheels, I'd appreciate it.
Old 06-08-2019, 09:52 PM   #5
Thanks for the reply big sky
Old 06-08-2019, 09:56 PM   #6
Ok will do! Where exactly should I measure to in order to get the correct hitch height? Bottom or top?
Carmen and the pack
Old 06-09-2019, 07:21 AM   #7
Measure the distance from pavement to the inside of the coupler socket. Please.
Old 06-09-2019, 09:32 AM   #8
Does this work for you?
Carmen and the pack
Old 06-09-2019, 09:50 AM   #9
Certainly gives me something to work with. The trailer level,yes?
I appreciate to taking the time to do so.
Old 06-09-2019, 10:13 AM   #10
Yes, I keep it slightly nose-down for drainage but I leveled it before taking the pic
Carmen and the pack
Old 06-09-2019, 10:18 AM   #11
Thank you. Kind sir or ma'am.
Old 06-09-2019, 07:27 PM   #12
Ma'am, and you're very welcome. Enjoy your rig!
Carmen and the pack
hitch
