Old 03-03-2015, 05:55 PM   #11
I'd make sure you check the water, on my brand new 2013 coachmen, the first time I take it no water, the valves are in the wrong position. Second time out no city water and a leaky valve. The water line was kink in the wall. Have them check it for you
Quacker24 is offline   Reply With Quote
Old 03-03-2015, 06:39 PM   #12
The water system can be (PDI Checked WITHOUT Water)! They can and do check the system with (Regulated AIR Pressure)! The only part of the system that cant be checked is the (F/W Tank and the supply line to the Pump! I had a KZ delivered that was still under (Air Pressure) from the Factory! The Drains had A/F in them. This was in the Winter,(7deg.F) Youroo!!
