Old 08-10-2014, 06:11 PM   #1
Paradise has arrived!
Paradise115's Avatar
walking on roof
I've seen a lot of posts about this. Some say yes, some say no. Is it ok to walk on the roof of my 2014 Catalina? Other than falling off the roof and killing myself, is there any possibility of damaging the roof?
Paradise115 is offline   Reply With Quote
Old 08-10-2014, 07:10 PM   #2
Plain Old Member
You probably had 2 or 3 people up there at once installing stuff when it was built. I've walked on every one of ours. Sure they flex a little, and some more than others. If you're concerned, stay towards the edges. Do you have a ladder installed? If so there's your first clue. Also, you cannot do proper roof maintenance as required for warranty if you don't walk up there. At least on mine you can't.
Sent by ME
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-10-2014, 07:23 PM   #3
mark0224's Avatar
My v lite has no problem with me walking on it (6'2" and 230 lbs of me) stay away from stepping near skylights. If your really afraid of it put a smooth piece of plywood gently on the roof making sure not to cut the rubber roof. Or sit on the roof and spread your weight out that way.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 08-11-2014, 12:59 PM   #4
Thanks folks. I feel a lot better about it now.
Old 08-11-2014, 01:35 PM   #5
TURBS's Avatar
He did ok.....
TURBS
"SABRE OWNERS UNITED"
Old 08-11-2014, 01:45 PM   #6
Brother Les's Avatar
Originally Posted by f1100turbo View Post
Attachment 60199
He did ok.....
TURBS
But, he is a professional.....
Brother Les
Old 08-11-2014, 01:46 PM   #7
TURBS's Avatar
Yeah don't bet on it!
TURBS
Old 08-16-2014, 08:33 AM   #8
jerry226's Avatar
I just cleaned my rubber roof with no problems.
jerry226 is offline   Reply With Quote
roo, roof
