If it's like mine, there's a panel you remove in the bunkhouse on the lower right corner of the wardrobe. It's directly behind the water.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
There should be a panel that is screwed close that can be access if you open the far right wardrobe door under the bed.
It's in the bottom of the last cabinet in the bunk house. It's on the left as you are facing the rear of the camper. There are to square tipped screws that are about 3" long. Unscrew those and the piece will slide out.
Side note: If you look carefully, you'll notice that the screws are not quite square, although a proper-size square drive will work. They're Robertson screws, probably a #2. Home Depot carries Robertson screwdrivers. I got a #1 and #2 in my tool box.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
