Old 05-09-2014, 06:11 PM   #11
MagnoliaTom's Avatar
I got it to light using a lighter but it doesn't stay lit
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is offline   Reply With Quote
Old 05-09-2014, 06:54 PM   #12
VinceU's Avatar
Originally Posted by MagnoliaTom View Post
No new tanks, but I will try to close and re open the valve. Thanks. The other thing I noticed was when it clicks, there is no spark. I lit it with a lighter and it came on but went out after a second or two.
If I remember right, the rod that acts as igniter is the same that heats up and actsas a proof of flame. Sounds as though there is something wrong with this part of the circuit.
Old 05-09-2014, 07:09 PM   #13
RSchleder's Avatar
Some/most water heaters have a couple of black reset buttons on them. They typically have a rubber cover over the buttons. Might try pushing them IF you have them on your unit.
RSchleder is offline   Reply With Quote
Old 05-09-2014, 07:24 PM   #14
VinceU's Avatar
Good point, however the gas valve would never open if button is tripped, op is getting enough gas for trial lite off although the trial fails.
Old 05-12-2014, 12:59 PM   #15
daydreaming about camping
jeeplj8's Avatar
keep in mind the water heater is at the back, and the tank is at the front, so at least 40 ft or hose the gas has to travel through. May not be your problem, but I know after mine ran dry and I replaced a bottle it took a while to get stove, the fridge and finally water heater to light.
However if you don't hear it sparking to ignite, then that is a problem all by itself.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-12-2014, 01:31 PM   #16
Denver, CO
garbonz's Avatar
on mine, the clicking is the spark.
2017 Fuse 23T
Old 05-12-2014, 01:32 PM   #17
I think the air has been bled out of the line...stove lights and fridge works on gas. I can hear the water heater click as it tries to light, just can't see any spark. Taking it to the dealer to check out
Old 05-12-2014, 01:54 PM   #18
jeeplj8's Avatar
if it clicks there should be spark. sounds like a dealer problem to me too.
Old 05-12-2014, 02:02 PM   #19
Sounds more like a thermocouple/sparker alignment problem. Get your manual and carefully re-position the tc/sparker with the burner. If it is too far away, it will not spark nor will it stay hot to allow gas to flow.
Old 05-12-2014, 02:14 PM   #20
Just A Member
marc7's Avatar
Have you tried shutting the electric side off so that it's only on propane?
Cheers!
2008 Toyota Tundra Limited
2013 Rockwood 8325SS Diamond Package
Days Camped 2012: 80
Days Camped 2013: 101
Days Camped 2014: 115
marc7 is offline   Reply With Quote
gas, heater, light, water, water heater
