Old 05-12-2014, 02:20 PM   #21
Herk7769's Avatar
Sometimes if the flue is clogged with debris (spider web or wasp nest), the propane mixture will be too rich to ignite or maintain combustion.
You could try blowing it out with compressed air or a water hose. Watch your eyes (goggles) if you use compressed air.
HAM CALLSIGN - KC3FFW
Old 05-12-2014, 02:26 PM   #22
I think he said he's not even getting a spark.
Old 05-13-2014, 07:41 AM   #23
heavyodie's Avatar
I think the person that said it won't light if you have a tank full of hot water is on the right track. Turn off the electric and then let the water run until you get cold water out of your faucet. Then try lighting it.
heavyodie is offline   Reply With Quote
Old 05-13-2014, 04:23 PM   #24
Denver, CO
garbonz's Avatar
My question is whether the "clicking" is the spark, which is what I think. What would be clicking? A relay or something.
I don't even know where I would look for a spark?
2017 Fuse 23T
Old 05-13-2014, 04:42 PM   #25
Herk7769's Avatar
The gas solenoid should not "click" more than once.
The DSI will fire as long as the control board is sending a "light" command. About enough time for 3 or 4 snaps of the sparker (about 6 or 7 seconds).
It will then go into a purge cycle and flush out the nozzle with propane prior to trying to light again. If the area is "flush" with propane, it will not light again. The unit will try this "light" then "flush" 3 times before it locks out and you will need to shut the propane switch off for a minute to reset the water heater.
ID:	52332   Click image for larger version
Name:	DSI explained.jpg
Old 05-13-2014, 05:14 PM   #26
MagnoliaTom's Avatar
Name:	ImageUploadedByForest River Forums1400019176.353548.jpg
Here's my water heater. Tried it again today, not lighting. I hear it click, then I hear the gas, but no ignition. Does it 3 times then it locks out.
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is offline   Reply With Quote
Old 05-13-2014, 05:35 PM   #27
heavyodie's Avatar
Originally Posted by MagnoliaTom View Post
Attachment 52337
If your sure you're hearing gas then it has to be an igniter problem. You can take it apart and make sure that there isn't carbon built up on it. Use some light sandpaper to clean it up and make sure that it is aligned with the gas stream. I just had to replace the gas valve on mine even though two different supply houses said those never go bad.
Old 05-13-2014, 05:43 PM   #28
Yes, it's gas. I can smell it. Funny thing is, I'm not sure it's ever worked on gas.
I think I've always used electric. The igniter seems clean, I think it needs replacing as there is no spark when it tries to light
Old 05-13-2014, 05:45 PM   #29
Attachment 52337
The spark should be in the chamber where the black wire hooks to the porcelain sparker. You should see a spark from the end of the probe to the burner itself. If not, consult the manual for the exact measurements the probe has to be from the burner.
If the sparker is too far away from the burner, it will not spark and if it is too close or close to something other than the burner it will not light.
Old 05-13-2014, 05:46 PM   #30
Herk7769's Avatar
Never worked on gas?
Clean that flue!
gas, heater, light, water, water heater
