Old 06-22-2014, 07:15 PM   #1
Water hose connection leaks on my 2015 Freedom Express
Water hose connection leaks, appears to come out around threads. Tried two washers, didn't help. Anyone have the same problem and solved it?
hydrope is offline   Reply With Quote
Old 06-24-2014, 08:34 PM   #2
Oddly enough my 2014 does to, once filled its fine. I've not taken a lit if time to investigate, sorry. I guess beings it doesn't leak once filled I feel better about it!!!
Krlpj05 is offline   Reply With Quote
Old 06-24-2014, 08:46 PM   #3
Try wrapping the threads with some teflon tape.
Old 06-24-2014, 08:50 PM   #4
RSchleder's Avatar
A slight 1/8 to 1/4 turn with a channel lock (pliers) after it's hand tightened should do the trick!
RSchleder is offline   Reply With Quote
Old 06-24-2014, 09:05 PM   #5
BamaBob's Avatar
X2 I always carry a roll of teflon tape. Better than over tightening with pliers IMO.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-13-2014, 03:14 PM   #6
Thanks guys, tape didn't work, got a machined brass hose end replacement and that stopped any leak.
freedom express, leak, water
