Water Leakage in APEX 215rbk
I have a major water leakage, probably from a split pipe/hose likely near the pump.
Does anyone having an APEX 215rbk know exactly where the pump is located? I'm on the road and this would keep me from trying to look in multiple places. Actually another APEX may have a similar layout and could be helpful
I just started a long trip and discovered that I probably failed to properly winterize my trailer this past March after returning from Florida(March 18 is still too early to escape major freezing in central PA). Developed some gastritis while in Florida and either forgot to winterize or did a lousy job(I blow the lines) on returning, and then didn't check before leaving again.
I say near the pump because it wouldn't pick up water from the fresh water tank. Hooking to campsite water caused a major leakage. After disconnecting from campground water, the water pump would deliver a low flow, which could mean an additional break after the pump.
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
