Originally Posted by TheRowlands
Also, I tool your advice and ordered it with both the 6 point leveling system and JT Strongarms. We also upgraded to a 15k A/C and the 2nd A/C. You mentioned rear LED's, but I don't recall seeing that as an option. Is this something you would recommend doing as an aftermarket upgrade? I'm not really sure how much advantage LED has over stock.
I highly recommend upgrading your rear lights to LEDs. The factory lights are junk and very dim especially if you're driving in bad weather and/or rain. These are the ones I purchased:
LED RV Camper Trailer Stop Turn Brake Tail Lights / License Light / Black Base
https://www.amazon.com/dp/B00LA59QZO..._5DEcxbQXY81MQ
They literally took less than 30 minutes to install. Here is a video review I did on them when I first installed them on our Travel Trailer. I removed them and installed them on our 360 about 3 months later.
https://youtu.be/9VFfzpz12uQ
Your rig is going to be great! Congrats!
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
