Old 01-31-2015, 08:54 PM   #1
Weight Distribution
Hi everybody..
We are planning on buying a Coachmen Clipper 17FQ. The GVWR is 3518 lbs. and the tongue weight figures to be about 300 lbs. +
We will be towing it with a 2014 Jeep Grand Cherokee. which is rated for 6200 lbs.
Do I need Weight Distribution and Anti-Sway stuff?? Of course the dealer says yes but I've been reading conflicting reports online.
If I do need it can you guys and gals give me some recommendations??
Thanks, Joe
meganjoe is offline   Reply With Quote
Old 01-31-2015, 09:21 PM   #2
Stormrider151's Avatar
300# on the ball. Probably won't need it. I had a Coleman pup that weighed more than that and only used a friction sway controller. Keep in mind that 300# may be dry weight. Add propane and a battery plus what you load for camping and the weights go up. If it were me I would probably wait to see how my TV reacted to the weight and go from there. But I would for sure install sway control.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 01-31-2015, 09:48 PM   #3
caper's Avatar
Loaded you will be well over 4000# and tongue weight will be around 400# I would be using a WDH with sway control.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-31-2015, 09:50 PM   #4
Herk7769's Avatar
I have heard that "the rule of thumb" for "Do I need a WD hitch" is:
Yes, if the trailer "loaded" is more than 150% of the tow vehicle's curb weight.
No, if it is less.
No empirical data to back that up; just what I have read.
http://www.jeep.com/en/jeep-capabili...dCherokee2Tab*
Here are the 2015 numbers.
Looks like just one rating...
HAM CALLSIGN - KC3FFW
Old 01-31-2015, 09:55 PM   #5
asquared's Avatar
Look at your hitch receiver. Somewhere stamped on it will be weight ratings for load bearing and weight distributing. If the predicted loaded hitch weight is over the load bearing weight then yes get a wdh. With that size tt, a friction sway bar should be fine for sway control.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-31-2015, 09:58 PM   #6
Evo2700's Avatar
Our first trailer was 2008 Fun Finder x160 that weighed about 3300 pounds when we were fully loaded. We towed it with a Jeep Cherokee. We didn't have a WDH, just a sway bar. Although we didn't "need" the WDH, it would have been really nice to have and would have made the drives much better. Looking back I wish we had WDH back then.
Although the Jeep can tow, they are not designed for that type of use so anything that will make it easier on the Jeep is best.
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
Evo2700 is offline   Reply With Quote
Old 01-31-2015, 10:36 PM   #7
bikendan's Avatar
most owners manuals have a towing section, which usually has a number that requires using a WDH.
as was said, the hitch receiver should have a label or stamp that gives a minimum number needed for a WDH.
you're pulling a single axle TT with a short wheelbase vehicle, HECK yea you should use a WDH.
not sure what "conflicting opinions" you're talking about.
i love my Equal-i-zer and there's no drilling needed.
Equalizer WDH
Old 02-01-2015, 08:20 PM   #8
I'm gonna take YOUR opinion and get one...Thanks, Joe
Old 02-02-2015, 03:25 PM   #9
Fluffywhitedogs's Avatar
We just picked up our 17bh this past weekend. It's only about 800lb more than our old trail runner but it does put quite a bit more weight in the hitch of my Toyota 4Runner and I really felt it. We'll be getting a weight distributing hitch for sure.
If the dealer was being straight, it will also help a bit with gas mileage?
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
weight
