Old 05-05-2014, 04:45 PM   #1
JonClark's Avatar
What am I doing?
Just a Newby here wondering if anyone knows how long it takes for the hot water to heat up in a 2014 Freedom Express LE 320bhds? De winterizing and getting ready for our first trip and aside of dealer not winterizing it I'm thinking I did something wrong. Purged replaced caps turned the valve under the bed and turned on the switch. What am I missing?
Sent from my SPH-L720 using Forest River Forums mobile app
JonClark is offline   Reply With Quote
Old 05-05-2014, 04:47 PM   #2
TURBS's Avatar
Is the water heater full?
Only way to properly check is to flip open the relief valve.
TURBS
Sabre owners united!
Old 05-05-2014, 04:48 PM   #3
TURBS's Avatar
This.
If it's not full you may have burnt the element out.
TURBS
Old 05-05-2014, 04:51 PM   #4
JonClark's Avatar
Thanks will try my luck at this now. Was hoping to have no issues but after a torn floor at delivery plus laundry list and now outside shower leaks from not being winterized, this will kill the wife's spirit
Old 05-05-2014, 04:56 PM   #5
JonClark's Avatar
Checked the relief valve, tank seams to be full. Guess I will give it a little while longer. Thanks f1100turbo.
Old 05-05-2014, 04:59 PM   #6
wmtire's Avatar
You need to always make sure the heater is full of water before turning on ANY switch.
Couple questions:
1. A: what brand water heater do you have?
B. If a dual powered Suburban brand.... When you said you turned on switch, is it the switch for the DSI/propane OR the electric heating element? If you just went "huh", then this may help:
Suburban's electric switch and much more
The water heater just using propane, will average around 15 minutes to heat a tank, but this time will vary depending on how cold the initial water in the tank is. You have to have propane tanks with fuel and the valves opened...to use this function.
If using the electric heating element only, it usually takes a little longer, but you must be hooked up to a form of 120 volt shore power for this side to work.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-05-2014, 05:04 PM   #7
JonClark's Avatar
It is an Atwood dual fire heater. Tried on gas pilot lights but when I try it on electric I don't hear anything. Can't imagine it's that quiet
Old 05-05-2014, 05:06 PM   #8
wingedone's Avatar
Just in case:
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 05-05-2014, 05:11 PM   #9
JonClark's Avatar
I got hot water!!! Thank you all. Sure I will have more questions but thanks for the quick responses. Hoping for happy trails
