Old 02-14-2016, 12:14 PM   #1
What brand tires recommended
Just wondering what various opinions were on brand name and quality of tires, before I replace. I know there are a bunch of factors just in general...?
Firemedic is offline   Reply With Quote
Old 02-14-2016, 12:14 PM   #2
Tires?
What size? What type?
ST or LT?
donniedu is offline   Reply With Quote
Old 02-14-2016, 01:27 PM   #3
tkmi's Avatar
Lt tires have less load value.
Don't give me meds.
Just let me camp!!!
2013 Silverback 33RL
2010 2500 RAM 6.7L
tkmi is offline   Reply With Quote
Old 02-14-2016, 01:31 PM   #4
fonzie's Avatar
good reading
https://www.google.ca/search?q=best+...uEM4nKeJHMgMAF
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-14-2016, 07:25 PM   #5
For ST tires I have had good luck with Maxxis 8008. I went up a load range for added peace of mind. Works for me. Good luck, John
shadows4 is offline   Reply With Quote
Old 02-14-2016, 08:59 PM   #6
I have the Power King Tow Max tires on my fiver and after reading everything, I am more than a little concerned. However, when I go online and look, I do not see anything better anywhere. The Goodyear Marathons have all the same problems.
So is there anything out there that is dependable? This is my 3rd fiver and my 5th TV and I have never had a problem with tires on anything and I am talking about pulling a Montana from Bloomington ILL to Newnan, GA in in two days, then from Newnan to Hendersonville in one day then to Columbia , SC in one day then to Jacksonville in one day then to Summerfield FL in one day. What has happened to the industry? If all these tires are really that bad, Good Sam Roadside Assistance - get ready!!
johnruff is offline   Reply With Quote
Old 02-15-2016, 02:46 PM   #7
Telstar's Avatar
The only tire I will put on my 5er is Michelin XPS RIB. Yes there expensive, but they are 10 ply steel and made for commercial trailers. Stay away from cross tread tired like those on a truck. I had to replace my last set after 30,000 miles, not because the tread was worn, but they had reached th maximum 10 year life.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 02-15-2016, 06:50 PM   #8
I am very surprised you have not received the wrath of the internet come down on you for this question as it is very played out.
I would just look for a major brand maybe a weight size up from the factory (as they also go cheap) and do not worry about where it is made as no tire is US made, they are all made all over the world by all the brands.
Hope this helps and Happy camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 02-15-2016, 07:16 PM   #9
wingedone's Avatar
Your problem is probably going to be tire size. Do you have 15" tires on your Apex?
Friend of mine has that size and finding 15" LT trailer tires is tough. Lucky for you, you have a light trailer and might be able to find something with adequate capacity. Get at least 20% over your needs if you can, for adequate safety assurance.
The only ST tire I have heard with any regularity of performance is the Maxxis 8008. Not enough that I would pick over an LT, but if ST is your only option...
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 02-20-2016, 09:06 PM   #10
I'm going to put load range d tires on mine pretty soon and plan on replacing about every 3 years. That's about the best you can do.
Crambo is offline   Reply With Quote
tire, tires
