07-12-2019, 07:58 PM
FLY4FUN
Where is my slide controller??
New owner of pre-owned 2014 Apex 22 QBS. So far I've looked in the front pass-thru storage, in the compartment where water pump/WH bypass is, under the entire kitchen sink/range area, beneath the bath corner shelves, under the bed and under the sofa...can't find the controller . (Previous owner has no idea where it is.) While I hope the need to access it due to a slide malfunction never happens, I'd sure like to know where it is... just in case. I'll sure appreciate anyone who may have a clue pointing me to its hiding place.
07-13-2019, 06:00 AM
Can you run 3800 fps?
If by 'controller' you mean motor, it's probably under the trailer between the frame rails. On the curb side of the trailer look for a little pre cut hole about an inch and a half to two inches in diameter. Thats where you put the crank handle in to hand crank the slide if the motor fails.
07-13-2019, 06:53 AM
In previous Flagstaff, mine was under the drawers, below the wardrobe. About 3 feet from the front of the trailer. Thankfully, accidentally found that before it was a problem.
Have seen it screwed to the ceiling in the storage. Good luck searching.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
07-13-2019, 07:41 AM
FLY4FUN
"where is my slide controller?"
Thanks for the replies -- my terminology is probably wrong in calling it a "controller", but it's the "computer" that monitors the Lippert slide system & displays diagnosis and (may) enable emergency retraction. This system doesn't feature a crank-in (or out), 'though I wish it did. I've seen other RVs with this system that mounted the little "box" in different places & just can't imagine why all weren't mounted where access is relatively easy...and obvious. As with other RV model specific items, the "generic" owners manual is worthless. Will keep searching and will report back!
07-13-2019, 12:57 PM
My Schwintek slideout has a controller, so youre using the right terminology. But I have a different brand of RV so can't help with location.
You'll probably have to get help from someone who owns the same model.
Mine is in the cabinet below the pantry. It also holds the water pump.
07-13-2019, 01:15 PM
I would suggest that it is generally mounted UNDERNEATH the slide, somewhere close by, but usually on the ceiling or wall high in the storage bay - but it could also be hidden behind a 'false wall' in the rear of a cabinet.
The Turners...
'07 Rockwood Signature Ultralight...
two Campers and two Electric cars : )
07-13-2019, 01:44 PM
DW's 401(k) Plan
Mine was behind a false wall in the storage compartment under the slide. I could also access it by removing the bed and take a panel off under the bed.
It will be REAL close to the slide or under it.
2006 Jeep Liberty Toad
07-13-2019, 02:46 PM
They hide them well!
On my unit I found it in a bin hold, but behind a panel that you'd never remove except to access this module and only if you knew it was there.
I found it because I was removing every panel to reveal wasted space to expand and know where things were.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
07-13-2019, 03:04 PM
DW's 401(k) Plan
My slide wouldn't move one morning while on a trip. Called my dealer's service department and they told me to take panels off to find the controller. Yeah, mine was buried, too. Wish I knew 2 days before the vacation what I know now.
07-13-2019, 03:59 PM
FLY4FUN
Thanks for the ideas and experience-sharing, folks! I'm still looking...and, looking for someone with the same camper ('14 Apex 22 QBS) who may have found the controller. Meanwhile, just still hoping that I don't need to know what I don't know...at least until I know it.
07-20-2019, 07:38 PM
FLY4FUN
EUREKA!! I found the slide controller! ...almost the last place I searched was the difficult to open panel beneath the entertainment system/TV adjacent to the slide (it actually isn't accessible with the slide "in"...maybe the factory felt that the slide being stuck "in" isn't a problem? In any event, if (when?) the slide is stuck in the "out" position I'll know where to find the controller to initiate problem solving. Thanks for all who helped "point" me in the right direction .
