01-13-2019, 09:52 PM
Will LP furnace run on DC/battery?
We have a new to us 2015 Coachman Clipper 16B (TT) that we have only camped in 3 times. I tested everything on one of out outings at a full service camp ground this past fall.
One thing I did not test because it was not needed is whether the LP gas furnace will work on battery/DC power. I guess the controller for the furnace and the fan are the only things that need power but I can't determine by looking at the diagrams or reading the manuals if this will work or if AC power is required. If AC is required, does this model have an inverter that kicks in from the battery power in order to make that happen? If not, can I add an inverter that will make that possible. (I'm going to be adding a good solar panel, controller, and upgrading my batteries in early spring so that we can do more "off the grid" camping.)
The current factory configuration is:
Furnace: Suburban NT 20 SEQ
Converter: WFCO, WF8735-PB
If no one knows for sure, who would I need to call at Forest River to be sure I was getting correct info?
Thanks for your help.
Outsider
01-13-2019, 09:59 PM
Your LP furnace does not need AC power although it does suck quite a bit of battery power. All this assumes it’s a common furnace.
01-14-2019, 01:13 AM
As Mr. Dan said, RV propane furnaces are 12v powered, NOT 110v AC powered.
They are the biggest battery drain in your RV. It uses 12v power to ignite the propane and to run the fan.
All shore power will do is recharge the battery while the furnace is being used.
01-14-2019, 01:20 AM
Just a note, the battery should be in good condition, and pretty much charged when you start the furnace. A gentleman found out the hard way that his battery was a bit low on water and therefore the furnace would not fire, the fan ran fine, just not enough juice to make the furnace fire!
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
01-14-2019, 01:50 PM
The converter will power the furnace directly, it doesn’t refill your battery as you use it. The charger will charge your battery also but if the shore power is connected the load is pulled from the converter not the battery.
01-14-2019, 01:52 PM
We found out the hard way about having a weak battery while using the furnace overnight in a dry camping situation. We ended up camping on a 25 degree November night in the Walmart lot near Roanoke Rapids, NC. We got permission from the store and parked near some grass at the edge of the Walmart parking lot and turned on the propane furnace.
About 3AM I woke to something spattering off the side of the RV. I could see my breath in the trailer. It was cold! The furnace had turned itself off when the battery power gave out. No power to run the furnace fan. When I opened the door to the outside, I found that the Walmart lawn sprinklers had turned on and were spraying an icy coating on the side of the trailer. Yipes!
I started and locked the diesel TV, got 12 v. power back, started the furnace and went back to bed for a couple more hours till dawn. But it was cold lesson in the need for a fully charged battery to keep the trailer warm overnight. (I'd add a second battery and maybe bring an inverter if we dry camped often and needed the furnace. the furnace fan does suck 12 v. power.)
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
01-14-2019, 01:54 PM
Just so everybody knows... YES the furnace does suck a lot from the battery, but here's my experience:
Outside Temp: 20's at night
Thermostat :65 evenings and night / Off in the Day (Because we're outside hiking or whatever)
Two deep-cycle marine batteries
We lasted 3 days 2 nights with about 50% of usable capacity left.
I wouldn't want to push it past 3 nights though, and we are very conservative with our power.
01-14-2019, 02:32 PM
The furnace is normally the highest 12v draw in your TT. The furnace, water heater & refrigerator also have a 12v propane valve that opens to allow propane flow when the unit needs to start. They all also have a 12v flame igniter.
In the case of the furnace however, you also have the 12v blower motor. This makes the furnace the highest drain on the batteries.
I also believe that constant 12v is also needed to keep the propane valve open while the appliances are running (someone correct me if I'm wrong......don't tell DW I said that...)
2014 Prime Time Sanibel 3250
01-14-2019, 02:38 PM
01-14-2019, 02:41 PM
Originally Posted by rracer5
That chart is great!
01-14-2019, 02:49 PM
Grammar Pedant
You can look up your Suburban furnace and see that it will consume 2.7 amps.
It's a good assumption that your furnace will run for 5-6 hours in a typical night, with moderate temps, and a low (~66 F) setting. So, 13-16 amps per night. If you camp 3 nights for a long weekend, that's 40-50 total amps. Because you shouldn't discharge your battery below 50%, that will mean you want at least 80 - 100 amp-hour battery. And, that's just for the furnace.
Add up your other uses -- lights, water pump, CO detector, etc. You can mathematically determine how large your battery must be.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
01-14-2019, 03:42 PM
Anther thing to know. Your thermostat is also 12 volt and gets its power from the furnace. Also, If you can stand it, at night Ill set the temp for 55 degrees and throw on an extra blanket. All the wet compartments are heated in mine when I use the onboard heat, no freezing then.
01-14-2019, 03:52 PM
Pheewww!! That's warm. We turn our furnace off at night unless it's going to be below freezing ......and then, we only set it at 45.
Nope!....I ain't kiddin'
01-14-2019, 04:00 PM
I set it at 40 overnight when home and dont winterize between trips during winter as long as day temps are in the high 30s to 40s. If Im in it overnight, I dont like going to the bathroom and freezing my butt!
01-14-2019, 04:06 PM
I try to make those quick trips but, sometimes the ole prostate don't cooperate!
01-14-2019, 04:17 PM
Shamelessly stolen from wmtire:
The below is a copy and paste, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.
You can just peruse at your leisure:
Basic electric:
Basic RV Electricity - RV Information (RV Maintenance)
RV Electric
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Installing a dedicated 30 amp RV outlet at home:
http://www.forestriverforums.com/for...tml#post231880
Suburban water heater (if applicable to your RV):
http://www.forestriverforums.com/for...tml#post327988
http://www.forestriverforums.com/for...ml#post1527599
Water Heater bypass/crossover valves:
http://www.forestriverforums.com/for...st-103381.html
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
http://www.forestriverforums.com/for...ng-133760.html
http://www.forestriverforums.com/for...ml#post1649595
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
2011 Traverse LT, 3.6L, FWD
01-14-2019, 05:07 PM
Originally Posted by Grapehound
We found out the hard way ... in the Walmart lot near
yep, and the only time it ever happened to us was fairly early on, while overnight at the CORPORATE Walmart lot in Bentonville, Arkansas, of all places!
It got extremely cold, windy, and freezing rain started thru the night - our furnace was running non-stop, yet I had not had a lot of experience with the generator, or better yet, the AGS(auto generator starter)...which is a life saver in these situations where you really want the generator to start automatically and recharge the batteries AS THEY NEED thru the night, without having to 'worry' while you sleep.
Because the batteries went too low, I couldn't even start the generator when I realized it at 2a.m... so I soon picked up a new LESSON - use the 'battery boost' Switch on the dash of the motorhome - tie in the Chassis and House batteries together - and voila!, the generator would start : )
The Turners...
01-14-2019, 06:12 PM
I read you question differently that the others. The heat of the furnish is fueled by LP. The fan operates on DC. You need both.
01-14-2019, 06:24 PM
The OP was speaking of a furnace. The entire question is "Can it run on 12v (DC) or does it need to have AC power?" OP knows it needs propane - see LP in the title?
01-14-2019, 06:48 PM
My furnace takes 5A based on my Victron 712 current measurements. Take anyone else's chart/numbers with a grain of salt since it isn't the exact furnace you have in your rig. With mine running 50% of the time, that's 25AH for a night. Personally, don't trust the numbers the manufacturers list. That number may be with just the fan driving no venting. If the fan motor is loaded down at all with venting, it's a whole different number. Measure it yourself.
On our very first camping trip with a 70AH RV/Marine battery, the battery was at 50% after only one night with the thermostat set at 50 and outside temps at 25 to 30.
Now that we have 2 100AH Battleborns, we don't need to worry much.
