Old 04-11-2014, 04:43 PM   #1
Black tank flush w/ 2 toilets
Seriously considering Columbus 3800TH with bath & a half. How does black tank flush work when having 2 black tanks? Is it a selectable single valve with single input, or 2 separate valves & inputs? I realize each has its own slinky connection, but can't tell from literature how flush is set up. Thanks.
dbear is offline   Reply With Quote
Old 04-11-2014, 07:46 PM   #2
My Cardinal 36LE has two black yanks one for each bath. There are two dump connections on the outside. I have a Y fitting to split the sewer hoses so I don't have to switch the hoses. There is also a wash out sprayers on each of the tanks, have two water hose connections for them.
Love my bath an half, kids don't mess up mine.
Hope this helps.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 04-15-2014, 09:38 AM   #3
*If* the 1/2 bath has a black tank flush (it may not), it would be a second hose connection.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
ependydad is online now   Reply With Quote
Old 04-15-2014, 10:38 AM   #4
mkoelzer's Avatar
I have a Brookstone 340LS by Coachmen with a bath and a half. Each black tank has its own flush inlet. On the picture, the top inlet is for the half bath (dump outlet behind axles). The middle one is the full bath (forward of axles).
2014 Brookstone 340LS
2015 Ford F350 CC/LB King Ranch 4x4 Diesel DRW
mkoelzer is offline   Reply With Quote
black, black tank, black tank flush, tank
