Old 10-28-2017, 08:45 AM   #1
Slyhuntr's Avatar
Blew tire on Puma, kudos to tire vendor and Puma
On a return trip from Arkansas last Monday we had a right rear tire failure on our TH. We are still running the tires that came with the trailer, Castle Rock tires from Lions Head. When it went it took the skirt above the tire and ripped loose the bottom section of the siding on the trailer above the tires. We were lucky that was the extent of the damage.
I want to give kudos to Lions Head and Puma, we are still in our first year of warranty and they both are stepping up to take care of the damage and replace the tire. LH is replacing all four tires as they feel the other tires may be compromised from stress of the blow out.
Eventually I am going to replace these "China Bombs" with USA made tires but I am impressed that the vendors involved are correcting this issue in a timely manner.
Cindy & Matt
2001 F250 Super Single Cab, 7.3L PS Turbo
2013 800 RZR-S
2017 PP 373QSI
Frog# OK-0063-135
Slyhuntr is offline   Reply With Quote
Old 10-28-2017, 09:14 AM   #2
I see you have 6 lug wheels but what size Tires came on your Puma? Youroo!!
Old 10-28-2017, 09:31 AM   #3
Brother Les's Avatar
It is good that you are safe. Any tire failure is very danger es.
Do you have a tire monitoring system? if not... why not?
Would have told you the tire was low on air and/or the instant the tire let go. From the looks of the tire and damage, you drove on that a good amount of distance before stopping.
Brother Les
Old 11-10-2017, 12:45 PM   #4
Had the same tire position fail 1st trip with our new TH,,only damage was a small dent on bottom of the metal skirt and the outrigger just behind the tire is slightly bent. So nothing really worth fixing. Replaced all 4 tires with LTs.
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
larrytbm is offline   Reply With Quote
Old 11-19-2017, 07:12 PM   #5
Slyhuntr's Avatar
They are 235/80/16
Don't have a TPMS yet, no good excuse other than no spare cash to spend at moment. I stopped right as it blew, was going about 65 mph on I-40, was pretty obvious when it went.
Cindy & Matt
2013 800 RZR-S
2017 PP 373QSI
Frog# OK-0063-135
Old 11-19-2017, 07:34 PM   #6
NMWildcat's Avatar
I realize a good tpms would have it's benefits. That's what my buddy keeps telling me, even AFTER his tire blew and his tpms alarmed about 20 seconds AFTER the fact.
Tpms is good insurance, but won't catch everything.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 11-19-2017, 07:36 PM   #7
Originally Posted by Slyhuntr View Post
They are 235/80/16
You should inspect the trailer for additional damage. Yesterday I found additional problems, not serious unless left un-repaired. The plastic underbelly fabric above both tires was torn from the blow-out. This exposes the wood floor framing and insulation that is directly under the exterior wall. And being directly above the tires, towing on wet roads will soak the wood and insulation leading to rot and mold.
Old 03-16-2018, 02:06 PM   #8
Hollywoodgt's Avatar
I think TPMS sensor is a must on a trailer and specially the bigger ones. You get that 5th wheel swaying and it's not fun.
Hollywoodgt is offline   Reply With Quote
Old 03-16-2018, 03:26 PM   #9
Sway ??? 30 years towing fivers and no sway, not the way they are set up.
Old 03-20-2018, 10:27 AM   #10
True that I never really did much towing with %th wheel always bumper pull so I forget the difference
Old 03-21-2018, 10:24 AM   #11
Truck System Technologies Rep
Hello,
Please feel free to contact me at 210-420-0132 if you all have any questions on the TST TPMS. Many FROGS rely on TST to alert them of a tire with low PSI, Fast Leak or High Temp.
Thanks,
Mike Benson
TST TPMS
210-420-0132
mbenson1234 is offline   Reply With Quote
puma, tire
