Old 11-08-2017, 04:26 PM   #1
Extra outlet in garage
Since the garage doesn't have a furnace duct (like most TH's), I need to use an electric heater. Problem is that there is just a single 15 Amp circuit for virtually all of the electric outlets in the trailer ( my last trailer at least had 2 circuits for the outlets). Anyway, using a single heater means nothing else can be used at the same time.
So for the garage I decided to utilize the 2nd A/C circuit to provided a dedicated outlet for an electric heater (since I don't need the A/C in the winter). Anyway, I installed a shallow metal junction box inside the return air chamber to tap into the power. Used surface mount raceway to run #12 gauge romex across the roof and down the wall to a surface mount outlet.
Now since there is an unused slot in the breaker box, I need to look at adding another circuit and one or two outlets in the kitchen cabinet for another heater option.
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
larrytbm is offline   Reply With Quote
