Old 06-26-2017, 06:23 PM   #1
Floor tie downs
2017 351 thss
The tie downs are in a crappy spot to secure my golf cart properly. The back middle has already pulled out of the floor after the first trip of 75 miles .
I'm looking for info about different mounting location or options on other mounting hardware .
Any pictures of different locations that anyone has in there toy haulers would be greatly appreciated.
I called the people at puma for info I asked if they had plans or blue prints for the layout of the toy hauler frame portion and they said they didn't have anything and where the tie downs are in the only place they can go . but I've seen them in different places on Google images.
Kristian is offline   Reply With Quote
Old 07-12-2017, 03:55 PM   #2
The tie down suck for sure. My puma 25fbc had tie down with longs screws going into the wood floor and then into sheet metal under the under seal. I haul a cycle so that wouldn't work. I got some red iron and reenforced the mounts and used long bolts with lock nuts. Sucks to have to do things right. While I was under the trailer I noted that several bolts were missing from the rear door hinge. I called the factory and they sent me a lifetime supply of hinge bolts in overnight mail!
Rick S is offline   Reply With Quote
floor
