Old 10-18-2014, 08:11 PM   #1
Has anyone else made this 12 volt mistake?
OK, First off, let me begin by saying that I am a Dummy. I was replacing the battery in my 2012 351 THSS, and I hooked it up backwards . Black wire to negative and white wire to positive. I was also hooked to shore power at the time. I went into the trailer, and the refrigerator was not running, or at least the lights were not on. Antenna booster and radio were not working either. Checked the fuse panel and noticed that I had burnt out a 15 amp fuse. Red light was on. Corrected battery wiring, replaced 15 amp fuse, and all appears to be working. I am sure I cannot be that lucky, so please tell me what else I may have messed up so I can check it out tomorrow. Going on a long trip this Thursday. Thank you in advance for any input.
McIII is offline   Reply With Quote
Old 10-18-2014, 08:19 PM   #2
Jerry01's Avatar
I would say that if you are hooked up to shore power, and everything works, then all is good. Maybe check the voltage at your batteries. If the converter is still charging them, then that is a good sign too. I would then unhook shore power and see if all of your 12 volt items still work. If so, then have a great time camping! Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 10-18-2014, 08:22 PM   #3
Rrickim63's Avatar
Been there, done that..thank you fuse panel..
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 10-18-2014, 08:26 PM   #4
jimdd810's Avatar
When they prepped my trailer they hooked it up back words. Needless to say I was not very happy. So much so that I made them come out at there expense and switch it around. No harm no foul
Life is a highway!!!!!
jimdd810 is offline   Reply With Quote
Old 10-22-2014, 06:46 AM   #5
mud yapster's Avatar
Way to go Jim that sounds like something my dealer would do. I wouldnt trust my dealer to make one repair right on my RV after the last and only repair I let them try to make.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-22-2014, 07:30 AM   #6
It happens. Thank goodness for reverse battery polarity protection in the converter.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 10-22-2014, 08:49 AM   #7
GASPEDDLER's Avatar
I did it on my first trip out with my new TT. It was dark when I installed my battery, thankfully no damage.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 10-22-2014, 09:00 AM   #8
acadianbob's Avatar
I'm guessing MANY people have done this; including me! It defies logic why they use white and black!! What wrong with conventional red and black?
You probably have a fuse or 2 to replace in your converter. I also had a blown fuse in the link to my sound system.
I'd mark those puppies somehow to make sure that it doesn't happen again. It may be difficult to remember which was which next year.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-22-2014, 09:08 AM   #9
TURBS's Avatar
They coordinate it with 110v wiring.
Why I don't know.
Turbs
Old 10-22-2014, 09:32 AM   #10
Dazed & Confused
M&K Hoffman's Avatar
Having worked in the electrical field for over 40 years, DC red=positive and black=negative is very ingrained in me. One of the first things I did to both the travel trailers I have owned is mark the battery cables as such with phasing tape.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
12 volt
