Old 10-17-2014, 05:56 PM   #11
Hi Mud: I hope you have fun dry camping this weekend. The Schwintek slides have a motor on either side of the slide and they use a controller to keep them in sink and according to the Lippert Master manual you can use it to reset the slides and put them into manual mode in an emergency.They also have a read out on them that will tell you what is wrong with slide. I haven,t been in to mine yet to look. The tech at my RV dealer told me today that he did not think that my big slide has a controller because it uses a single motor and I don,t remember what the manual says so I will have to look.
mark wyoming is offline   Reply With Quote
Old 10-18-2014, 10:54 AM   #12
mud yapster's Avatar
Hi Mark, I haven't looked to see if mine is a single motor or dual motor slide yet but I will let you know.
Battery life after the self leveling and slide outs opened was 12.7v the only thing running after that was the fridg. electronics and fridg fan. I put a 10watt solar panel on the battery but that didn't do much and the battery got down to 12.4v so I fired up the generator for 1 hr. and battery came back up to 13.1 so I need a lot more solar panel. Just to keep the battery up from running the fridg. I can't post pic with this phone but I will Monday of my camp spot. Hope you have a good weekend. Oh and I took 2 showers so using the water pump, works good. GC went up to the house and showered. LOL she is spoiled I think.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
cat, inverter, location, pump, water, water pump
