Old 11-29-2012, 08:25 AM   #1
TJB
jt stablizers for Columbus 320rs
I just got the 320rs with 6 point leveling system. I purchased the jt stablizers and I would like to get a picture of the back two because the stablizers are too short and won't reach the bracket. Thank you.
TJB is offline   Reply With Quote
Old 12-11-2012, 09:33 AM   #2
I'n negotiating for a 320 RS and not sure what the stablizers are or what they do. Can you explain or provide a picture/link?
Mr.z is offline   Reply With Quote
Old 12-11-2012, 09:41 AM   #3
TURBS's Avatar
Get them! They stabilize your trailer against bounce and movement.
You'll regret not getting them.
Turbs
Old 12-11-2012, 09:56 AM   #4
I noticed there are two black brackets in the center of the camper between the landing gear. They appear to be welded to the upper frame and both have a hole in them where it appears you attach a diagonal brace. Is this for the stablizers? If so, where would I get that brace, and is one better than another?
Old 12-11-2012, 09:58 AM   #5
Originally Posted by f1100turbo View Post
Get them! They stabilize your trailer against bounce and movement. You'll regret not getting them.
Turbs
X2. They really helped on our Sabre 5er.
Old 12-11-2012, 10:03 AM   #6
Lynkage's Avatar
JT Strongarm
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 12-11-2012, 04:01 PM   #7
TJB
Mr.z get the stabilize they cheaper from the factory and you will need them. I would also recommend 6point levering system it is elect. not hyd.
Old 02-16-2013, 11:04 AM   #8
Do you need the stabilizer with the 6 point leveling system. We got our 320RS in January and haven't had it out yet. I guess I was under the impression that you wouldn't need the stabilizers with the 6 point.
ee2810 is offline   Reply With Quote
Old 02-16-2013, 11:30 AM   #9
Dave_Monica's Avatar
I don't believe that the 6 point leveling will keep the camper from rocking around when you're moving inside it. That's why they offer the JT Strongarm stabilizers as an option.
Dave
320rs
