Old 01-16-2014, 08:09 PM   #1
New 5th Battery! I don't get it.Help
Im a boat guy and on all my boat's I ever owned there was always a battery switch! But not on my new Puma Unleashed. I know that most of the time the RV will be plugged in. why not a cut off switch of some kind. Now if I install a cut off switch @ the Battery. If the switch is off, the battery can't be charged when plugged in correct? Thanks for Any insight on this .
firstclark is offline   Reply With Quote
Old 01-16-2014, 08:21 PM   #2
Correct.
Wiscampsin is online now   Reply With Quote
Old 01-16-2014, 08:21 PM   #3
Rrickim63's Avatar
only use the battery disconnect when the trailer is being stored or not used.the battery will not be charged when the disconnect is activated.
2006 roo 23b
99 Silverado xtra cab with 4.8 and tow package
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 01-16-2014, 08:25 PM   #4
Campster's Avatar
I installed a battery disconnect switch on our travel trailer. I found out that there are things (alarms, etc..) that run off the battery all the time thus creating a constant drain on the batteries. I installed it to the negative side of the battery. I set the switch to the position which connects the negative terminal of the batteries to the trailer ground when I want to charge the batteries using the inverter. When the battery is charged I set the switch so that the negative terminal is disconnected from the trailer ground. This allows my batteries to stayed charged for a longer amount of time.
Campster is offline   Reply With Quote
Old 01-16-2014, 09:07 PM   #5
OK Thank You . We really like our Puma. Just want to understand things a little more. again Thanks everyone.
battery
