Old 03-16-2018, 03:17 PM   #1
Hollywoodgt's Avatar
On board generators
Curious on what people are using for fuel. Is it more common to tap off the fuel tank in the back of the RV or propane or is the fuel tank in closed with the Generator
Thank you in advance
Hollywoodgt is offline   Reply With Quote
Old 03-16-2018, 03:30 PM   #2
Gas generator is plumbed into main gas tank from the manufacturers
AbdRahim is offline   Reply With Quote
Old 03-16-2018, 05:18 PM   #3
Fulltime family RVer
My toy hauler has 2 gas tanks under the garage. One is connected to the generator.
The other has its own fuel pump.
Old 03-16-2018, 09:19 PM   #4
So your saying if my 5th wheel is Generator prep then it has a fuel tank for a generator in it?
Old 03-16-2018, 09:27 PM   #5
Iím saying MINE does. And itís common for toy haulers.
Iím not sure how non-toy haulers do it.
Old 03-16-2018, 11:01 PM   #6
rmac04401's Avatar
On board generators
How does the on board genny work? Will it kick on automatically or do you have to flick switches?
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 03-16-2018, 11:05 PM   #7
For now, flick switches.
When I add solar and/or an inverter/charger, itíll have automatic generator start capabilities.
Old 03-17-2018, 09:15 AM   #8
there are several different ways to provide fuel to an on-board generator. if in a motor home the generator will normally be connected to the motor home fuel tank. it will be either a gas or diesel generator based upon whether the motor home is gas or diesel. for a toy hauler that has an internal fuel tank (for the toys) the generator will normally use the fuel from the toy hauler tank (gasoline) though it would be possible to install a lp fueled generator and use lp gas from the propane tanks. for a trailer that only has propane tanks the generator will be a lp fueled generator and use lp gas from the trailer tanks. many onboard generators are started / stopped by manually flipping a switch. it is possible to upgrade many onboard generators to use an auto-start system that will automatically start/stop the generator based upon battery condition (ie need to be recharged) or temperature (ie need to run an a/c). hope this helps
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 03-17-2018, 09:26 AM   #9
World Wide Wanderer
wahoonc's Avatar
Most fifth wheels don't come with fuel tanks, the toy haulers are the exception. Usually all a generator prep package provides is a place to put the generator, some wiring, maybe a switch and possibly a removable panel in the cargo door for ventilation. Most fifth wheels use LP to run the generator to keep from having to haul or add tanks for gasoline. But there are always exceptions.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-18-2018, 02:18 AM   #10
Thanks for the input. My unit is a toy hustler and has optional fuel tank and pump.it also has the upgraded set up for generator so maybe it does. Also has the electrical set up for 2.nd a/c .
Thank you everyone for all your input. I have some things to look at
Old 03-18-2018, 04:13 AM   #11
bikendan's Avatar
Toy hustler?🤣
Equalizer WDH
Old 03-19-2018, 09:03 AM   #12
Sorry Biker Dan must of auto corrected its a Toy Hauler ........
Anyway I did look at the compartment next to the Generator compartment and can see that it is wired for the Gen. I see a what appeared to be a capped fuel line also. So I'm good to go then :-)
Old 03-19-2018, 09:10 AM   #13
also check to see if you already have a transfer switch installed. if you have the generator prep you probably have it.
Old 03-19-2018, 09:15 AM   #14
B and B's Avatar
Originally Posted by bikendan View Post
Toy hustler?🤣
Thats derogatory term for a RV Sales person...Some fit the description..
generator
