Old 06-27-2013, 08:26 PM   #11
Oaklevel's Avatar
no washer option it would have to go in the garage...........Many other posts on here on how to get more bed clearance on a Puma Unleashed 351...... the bed set ups are the same..........
Had our 356 a little over a year Happy Happy Happy
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-15-2013, 11:42 AM   #12
Hey guys, thanks for all the inputs. I just got back from vacation and have not had time to call Palomino yet. I did find a picture of 2014 and it appears they increased the height of the beds, so that may not be an issue. It looks to be higher than the loft now.
madbare is offline   Reply With Quote
Old 08-07-2013, 08:08 PM   #13
The picture you show above is a unit with only one bunk, and therefor has more clearance.
TheGoodwin4 is offline   Reply With Quote
Old 08-10-2013, 04:06 PM   #14
No that is a double. Palomino did confirm they raised the bed rails and the clearance with the dual bunks is now 75". Look at the bottom of the rails and compare to the previous models.
Old 08-11-2013, 03:29 PM   #15
jlbreaux's Avatar
Wonder if I could raise mine without screwing something up?
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 08-11-2013, 08:16 PM   #16
I would contact Palomino and see if you can just move the tracks up the wall. Assuming the wiring is not in the way, I bet you could.
Old 02-15-2014, 10:28 PM   #17
Anyone have problems with the water heater? Mine works in gas mode, but nothing in electric. The heating element is good. When I put a volt meter on the element leads, I only get 15 volts and it slowly drops off. Any suggestions?
Jphippsjr is offline   Reply With Quote
Old 02-16-2014, 09:58 AM   #18
Cosmo's Dad
grooveman's Avatar
Assuming you switched it on with that little rocker switch on the front of the water heater?
2012 Puma Unleashed 356QLB
2012 F350 Lariat Diesel
2-2011 Honda Rancher quads
1- Spoiled Rotten English Springer Spaniel
grooveman is offline   Reply With Quote
Old 02-16-2014, 11:55 AM   #19
Yes. Even changed the switch, thinking that may be the problem.
Old 05-03-2014, 08:01 PM   #20
Ever get hot water heater working?
bubbubouy is offline   Reply With Quote
