Old 08-02-2015, 07:06 AM   #301
Oaklevel's Avatar
Originally Posted by doodler View Post
If you will search "puma unleashed modifications" on here, on page two there is some discussion about this. Sorry I don't know how to post link in here for you.
x 2
Also some have turned the "L" brackets holding the bed frames over to gain more head room
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 08-02-2015, 07:53 AM   #302
FandRChambers's Avatar
Look inside the rails....from top down...you should see the wire running to the switch held in place by a screw...unscrew and move to the position you choose
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 08-02-2015, 10:59 AM   #303
Originally Posted by gilwilliams101 View Post
I AM A MORON!!!
Can someone post a pic of the limit switch for the beds in the garage? I have looked at the rear vertical rails several times and see no limit switch to relocate in a higher position.........
Take a look at this page in the Puma Unleashed Modifications Thread doodler mentioned, don't forget to remove the "stop screws" on both sides of the rail.
2013 Puma Unleashed 351THSS with Goose Box
2006 F350 KR DRW
bluefinger is offline   Reply With Quote
Old 08-04-2015, 09:32 PM   #304
Did it-works great-THANK YOU ALL for the help!!!
gilwilliams101 is offline   Reply With Quote
